Can you assist in getting a manual for a Lux 500 thermostat?
    President:
  • 2,777 Answers
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
There are two versions, the 500b which is this one:
http://www.luxproducts.com/support/TX500b_Eng_WebManual.pdf
And the 500E which is a newer model:
http://www.luxproducts.com/support/TX500E_ENG_Manual121409.pdf
Posted on Oct 14, 2010
  • Tim Grayson
    Tim Grayson Oct 15, 2010
    If possible please come back to the question and rate my answer. It would be much appreciated if you could rate me 4 thumbs up. I am in very desperate need of the rating! Let me know if you need more help.
    - Thanks -
    Tim
  • prchrksr Mar 13, 2011
    excellent - got manual right away - 4 thumbs u[
Flashing filter light on my lux 500e thermostat
turn the knob to filter & hit enter...should reset
Dec 17, 2013 | Lux Thermostats TX500E 5-2 Digital...
Tip
Lux Thermostat 500
The Lux 500 Thermostat is an affordable programmable thermostat that gives you a very easy way to customize your heating and cooling temperatures to your schedule. The programming of this thermostat is easily the simplest that I have found in a programmable t-stat.
The Lux 500 series thermostats are a great economical way to reduce energy and utility expenses by raising or lowering your temperature settings a the times you set. The installation is so easy that most any DIY’er can install this thermostat. It has an easy to read display and the rotary dial makes the programming very user friendly.
A few of the other great features of this unit are, a keyboard lockout, and an air filter reminder.
This thermostat can be used on any 24v AC or 750mV single stage conventional heating/cooling system. Single stage heat pumps without auxiliary heat will also work with this thermostat.
Here is a summary of the features of this thermostat
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • 5 - 2 Day programming
  • 4 Periods per day
  • Large easy-to-read display
  • LUX patented user-friendly Speed Dial®
  • Filter usage monitor and alert
  • Default Energy Star approved program
  • Temporary Temperature Override
  • Temperature Hold
  • Keyboard Lockout
  • Temperature Calibration
  • Swing Settings #1 - #9
  • Fahrenheit or Celsius temperature Scale
  • 12/24 Time Format
  • Low Battery Warning Indicator
  • Mercury Free
As you can see this thermostat will give you a lot of great features at an affordable price.
on Jan 16, 2010 | Heating & Cooling
Tip
Unlock Lux 1500 Thermostat
Your Lux 1500 thermostat is showing the “lock” code and you cannot change your program. How do you get the thing to unlock so that you can make changes. The answer is actually very simple.
Hit the “next” button three times, then hit “hold” this will unlock your Lux 1500 thermostat.
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
Snowflake symbol on thermostat
Copy following link for Lux product manuals
http://www.luxproducts.com/instructionmanuals.php
It might mean that AA batteries needs to be changed.
Or it might mean 2nd stage heating cycle.
Air filter needs to be changed.
Tech assistance 856-234-8803
Oct 26, 2012 | LuxPro PSP711TS Touch Screen Programmable...
Lost manual for lux 1500 thermostat
Visit this link LUX INSTALLATION AND OPERATING INSTRUCTIONS SMART TEMP ELECTRONIC THERMOSTAT TX1500
Also in this other: Lux 1500 Thermostat Instructions (PDF)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Cameras
My lux TX1500a home ac thermostat unit is ''locked'' help !!
you press Next, Next, Next, Hold. This locks and/or unlocks the thermostat. I had the same problem but found the manual online.
May 18, 2010 | Heating & Cooling
Gooman heater connected to electronic lux 500 thermostat. no response from heater at all. tried changing batteries in thermostat.could thermostat possibly be bad. had both for approx.11 years
Remove t-stat and remove red and white wires and connect them, if unit starts then it was the t-stat.
If not go to furnace and remove same two wires at furnace and jump out at circuit board or connect wires FROM furnace, if it starts the problem is in wires.
If you have power to furnace?? and nothing happens it is either a bad board or inducer motor (little one) is not starting. Remember that their is a fuse on corcuit boards that need to be checked.
Feb 04, 2010 | Goodman GMS80903BNA Heater
Can't find instruction manual
Hello
At the link beow you will be able to download the manual for the requested manual.
http://www.retrevo.com/support/Leica-D-Lux-3-Digital-Cameras-manual/id/522dj983/t/2/
Kind regards
Andrea
Jan 24, 2010 | Leica D-lux 3 Digital Camera
Heating & Cooling Logo
1,256 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
