Question about GE Refrigerators
My "frost free" freezer is frosting up. What is the problem? This is occuring about every ninety days. I unplug the refrigerator, allow it to thaw and then plug it back up. All is well for about 90 days and then the process must be repeated. winston
    President:
  • 670 Answers
Your defrost circuit has failed. It is the circuit that automatically turns off the compressor and turns on a heater to melt the ice build up on the evaporator coils. It is made of of 3 parts, the defrost heater, the defrost thermostat and the defrost timer (if it is an older model, if newer, then a control module.) The typical failures are with the defrost heater and the defrost timer.
Don't know what make and model is your fridge since you did not supply it. If it is an older model, it might have a defrost timer that turns off the compressor every 6 hours and turns on the heater for 40 minutes. As the coil reaches 40 deg F, the defrost thermostat, cuts off the power to the heater. After the 40 minutes are up, the compressor restarts and the cooling cycle continues again. If you have a newer model, the defrost is controlled by the an electronic control module.
If it has a timer, it should be located near the bottom of the refrigerator or in the temperature control box in the fridge compartment. There is a cam that can be turned with a flat screwdriver, turn it until it clicks. Plug the fridge and listen for the sound of cracking of melting ice. If the compressor does not start after 40 minutes, then the timer needs to be replaced.When you need to manual defrost your fridge, unplug it and remove the back panel in the freezer and you will see the evap coil iced up. Use a hair dryer to melt the ice. Attached to the coil is the heating element and the defrost thermostat. You can check the heater with an ohmmeter. It should read less than 50 ohms it if good and read infinity when bad. If the heater is ok, then you need to check the module or timer.
Hope this helps you.
Posted on Oct 14, 2010
I have a Beko frost free freezer I can't open the freezer door it hasn't been open for months
Probably not frost free then. unplug the power and wait for it to thaw.
Aug 29, 2017 | Beko Refrigerators
Freezer is continuing to run and is forming some ice on back wall of freezer. Refrigerator is not getting cold.
You have a defrost problem. If you drop the back panel and have a full coil of ice. Then you have a defrost problem. If you only have half of coil of frost. Youhave a sealed system problem. More than you can handle you will need a tech. Ok if you have a defrost problem you thaw with a hairdryer. You should unplug and melt all the frost. Then you have about 7-10 days that the box will work. This will allow you some time to get it fixed. Hope this helps
Aug 22, 2011 | Amana ABB2223DES Stainless Steel Bottom...
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool...
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Aug 21, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Frost buildup
you need to check the defrost circuit and make sure the heater is working and the unit goes into the defrost mode.
also check and make sure the temp sensor is good
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer builds up with frost about every 60-75 days. have to empty the freezer and allow to thaw for a few hours
I think I can assume the freezer isn't a "frost-free".
A short physics lesson; hot air holds more moisture than cold air; hot air will flow from a warm area to a colder area, and the colder area will cause the moisture to condensate and freeze(if colder area below freezing, as a freezer should be), causing frost build up.The more often the freezer is opened, the more frost will build up.
Now for 3 possibilities:1) If it is a self-defrosting type, check your defrost timer control...not working, or not working often enough.2) Door seals damaged and need replacement.3)Make the kids stay out of freezer.
Mar 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frost build up in freezer
The frost is preventing the evaporator fan from circulating the air.
Check that it is operating properly - and thaw out condenser if needed.
A hair dryer will work good.
Verify the fan is operational after thawing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Is there a way to disable the frost-free feature on amana freezer
If you disable the frost free feature you will have to defrost every 10 days.
But, yes,it can be done.
Aug 05, 2009 | Kenmore 53542 / 53544 Side by Side...
Whirlpool arc7612. Fridge not getting cold. Freezer obviously working as it frosts up despite being 'frost free'. Slight gap in door seal near top of door. Last time we had this happen I unplugged it for a...
You have to replace the door seal. The seal may be a mundane technology and it isn't the only technology making a refrigerator frost-free, but it is the most important one. Warm moist air enters through the gap in the door seal, condenses on cold surfaces and freezes. The frost interferes with airflow and prevents the system from keeping the fridge cold. Turning it off for a day allowed the frost to melt.
Aug 03, 2008 | Whirlpool Refrigerators
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
