Question about Maytag MER5755QAS CleanDesign Electric Kitchen Range
Maytag MER5755QAB gemini bake light flashes when I try to bake and oven will not heat
  • Greg Butler Oct 14, 2010
    would that cause the broiler to stop working also?
  • Greg Butler Oct 19, 2010
    heating elements are fine, still trying to find the problem. maytag does not have an answer.
    Problem Solver:
  • 87 Answers
U need a new element
Posted on Oct 14, 2010
Getting tu the heating element on a maytage oven model #mer5755qab how do I get to that element . is it on the top or under the botto,
Hello Jerry,
That bake element is accessed from under the floor of the the oven...in th erear of the floor is a couple screws if ya remove those ya can pull up the the oven floor up and out from the rear to the front the bake element will under of that floor.
BEFORE ATTEMPTING THAT BE SURE TO DISCONNECT POWER TO THE OVEN
Sep 30, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Gemini double oven flashes F1 and stops heating.
I am attaching a Gemini manual. The checking procedures are the same for your oven.
Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
Feb 03, 2010 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Gemini oven. The top oven heats but the bottom oven doesn't.
i take its gas by the model number u prob need a new gloe bar or ignitor for ur bake on the bottom, call for service or resaerch the part at sears with there research online
Jan 28, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Bottom oven will not heat up.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jun 11, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Top Oven Stops Working
Sounds like a bad sensor for the oven here is the link to the repair manual to help you out
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Feb 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER5755QAS CleanDesign Electric Kitchen Range Logo
374 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
