Question about Philips Televison & Video
I have a Philips Magnavox 32" CRT TV. Model # TS3254 C102, manufactured Oct '97. in Greensville TN, USA. While watching it the other night, it just went black on me, with no sound. The green power indicator stayed on. I tried unplugging it for a while but when I turn it back on, only the green power indicator stays on, no pic, no sound. Can someone please offer some suggestions. At the time of purchase it was Consumer Reports Best Buy. Thanks
    Top Expert:
  • Philips Master
  • 74,136 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on May 01, 2015
Does anyone know the original price of this tv..if so please email me tracemarielongo@gmail.com
Posted on Apr 30, 2015
SOURCE: black screen no sound
Look at this
Phillips/Maganavox TS3258 Dead, HOT shorted R&R Flyback, HOT
Transistor,#3610- 22k, #6328 SMD diode, #7325 SMD Transistor and Check
#3611/3608 190 ohm resistor by #3610
TELEVISION MAGNAVOX TS3258 Flyback Bad Replace fly -
R3610,22K-R3331,47K(SMD)-D6328(SMD)-Q7325(SMD)-IC7150
TELEVISION MAGNAVOX TS3258C101 DEAD Shorted flyback, will also damage
IC7150, R3610, R3331, D6328, and Q7325.
Posted on Nov 13, 2007
Shuttle83
  • 1139 Answers
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
SOURCE: RCA 32v434t
Has anyone confirmed what the problem is? Mine wont turn on. The red light next to the power button just stays lit when pressed.
Posted on Jan 08, 2009
  • 8457 Answers
SOURCE: I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Posted on Aug 20, 2009
Testimonial: "thanks for the info."
nileshsingh2
  • 246 Answers
SOURCE: no sound, no picture. tried unplugging and
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Posted on Oct 25, 2009
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
Tip
Magnavox Factory Service Centers in USA
ATLANTA Phillips Factory Service
550 Franklin Road., Suite F
Marietta, GA 30067
800-273-1501
TAMPA
Philips Factory Service
1911 US Highway 301 North, Suite 100
Tampa, FL 33619
800-442-2027
SAN FRANCISCO
681 East Brokaw Rd.
San Jose, CA 95112
800-300-9013
HOUSTON
1110 N. Post Oak Rd., Suite 100
Houston,TX 77055
800-952-3254
CLEVELAND
950 Keynote Circle
Brooklyn Heights, OH 44131
800-331-7037
DETROIT
25173 Dequindre
Madison Heights, MI 48071
800-438-1398
DALLAS
415 N. Main Street, #107
Euless,TX 76040
800-952-3254
LOS ANGELES
20930 Bonita, Ste.V
Carson, CA 90746
800-300-9013
CHICAGO
1279 W. Hamilton Pkwy.
Itasca, IL 60143
800-531-2922
KNOXVILLE
One Philips Drive
Building 2
Knoxville,TN 37914
800-821-1767
PHILADELPHIA
354 Dunks Ferry Rd.
Bensalem, PA 19020
800-847-9320
on Jun 02, 2009 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox TS3254 C102
I would suspect on this model which is not projection but a 32 inch crt type set---broken or bad solder connections first and second something triggering the shutdown (latch) circuit it uses.
Someone would have to be able to open it safely and remove board and look for around the high voltage transformer cracked or poor connections---instant shutdown would almost always be a short of some type but if it runs f o r a few minutes a bad connection is more likely---even one.
Oct 23, 2012 | Televison & Video
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
TV keeps shutting off and changing channels
hide all your remote controlls and put some tape over the front cover of the tv where you think the remote control reciever may be , if this fixes it then it means something is amiss with a rogue remote , most likely batterys..could even be sunlight ??
Jul 03, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
Jun 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Televison & Video Logo
211 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
