Question about Bissell Vacuums
My carpet cleaner is broken.We have had it two years and used it three times.It won't **** up dirt.
  • 1,041 Answers
Here is a Link to one of my Tips:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
This should solve the problem.
Good Luck!
Jim
Posted on Oct 14, 2010
  • Jim Parker
    Jim Parker Oct 14, 2010
    Sorry, I sent you the wrong Link. Here is the right one. You will have to copy and paste it in the address bar at the top of the page.
    www.fixya.com/support/r6323257-bissel_carpet_cleaner_dispense_water
    Jim
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Which is the best caprpet steam cleaner mid priced?
I would recommend the Hoover brand. The Bissell's are very problematic, they have belts that break and issues with the heating elements. Hoover Steam Cleaners can be repaired and are simple to use. The price range is generally $180 - $300
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
