Question about Gateway GM5620 PC Desktop
Gt5620my gateway pc keeps on saying installing 1of3 then shuts off all the time it will not turn on so i want to see if we can reset my whole computer even if i lose my stuff on it
3 Suggested Answers
dodgecharger
  • 254 Answers
SOURCE: Gateway lcd monitor
First, narrow down the problem to either the monitor, or to the computer itself. Either try the monitor on a spare or friend's computer, or try a known working monitor on your computer. I'd guess your computer is where the issue is at- it isn't booting the Operating System (MS XP or whatever O/S is present on the hard disk. if the computer is the issue, try booting from the CD which came with the computer, (assuming you have that CD). Or, you could see if some computer tech savvy person has a bootable floppy diskette. Basically a "no-boot" problem, can point to a number of problems: hardware issue (bad hard drive etc.), or an operating system problem.
Posted on Jul 10, 2007
  • 256 Answers
SOURCE: gateway 450rog computer constantly restarts
remove all other devices hooked to your pc except for the basics, mouse and keyboard. then try the last known good configuration. press F8 before it boots to windows then choose known good configuration.
Posted on Apr 01, 2010
My Gateway laptop won't boot up it keeps saying "failure configuring Windows updates reverting changes" Do not turn off your computer
Make sure the Date & Time are set correctly on your machine. That can interfere with Windows Update. If your computer has the wrong date/time, you need a new cmos battery (available anywhere). Then, If you are running Windows 7, try the "Windows Update - Reset" options here... http://www.sevenforums.com/tutorials/91738-windows-update-reset.html?filter
Jul 16, 2014 | Computers & Internet
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
Gateway 450rog computer constantly restarts
Mar 31, 2010 | Gateway 450ROG Notebook
My gateway 510x keeps shutting itself off. Sometimes after 5 minutes of booting up sometimes after 30 seconds. What could be the problem? Tried removing dust from the inside but that did not help.
sounds like your processor fan shut down and now your processor itself shuts off when it begins to over heat replace fan asap and don't keep trying to turn it on because you'll burn it out
Mar 31, 2010 | Gateway 510 X PC Desktop
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
Computer works for a bit then the whole screen turns to pixels. we bought this pc brand new about 3 months later started showing images pixel up, noe the whole screen turns to pixels..and cant see nothing...
Well, the first thing you can try is replacing the monitor cable or monitor, and that is less expensive. If it still gives you trouble, you may need to see about replacing the video card; there are modestly priced, reliable ones that are relatively easy to install, yourself. I'd recommend installing the new VC after taking out the old one, just because your system will be happier. Then see if after any of these steps, the monitor isn't working better.
If it still presents a problem, it may be an issue with the motherboard, which means basically replacing the whole system, for the cost and time involved, depending on your motherboard.
Oct 22, 2009 | Gateway GT5220 PC Desktop
Power supply
This problem its common if you install a incompatible card, sometimes its possible to solve resenting bios, just remove the battery and disconnect the power cord for a few seconds, but remember, time and date will reset.
Aug 29, 2009 | Gateway GT5014 PC Desktop
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
Gateway 3550 Internet shuts off every 10 minutes
I have a gateway laptop with Vista that does the same thing.
In the control panel/power settings, ID what power scheme you are using.
I found that when on power saver mode the wireless and CPU were throttled down to conserve power. In Vista you can adjust these up to max power while keeping the other features on the default power saver settings. It improved the dropped connections dramitically. To end the finger pointing I signed up for connection monitoring using DSL reports (DSLreports.com) This service sends a ping to your modem every 10 minutes and charts your ISP uptime. Using this service I was able to determine that it was not my ISP.
Good luck.
Nov 07, 2007 | Gateway 3550GZ Notebook
Gateway GM5620 PC Desktop Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
