Question about Hitachi 53SWX12B 53" Rear Projection Television
Picture is out!
There is power coming onto the set. I have unplugged the entire TV set for a few hours to see if there is any effect - nothing. The menu screen, volume indicator, or channel number will not even display, so I know it is not a cable issue - I just have a black screen. Am I hosed?
  • dthomasbcm Jun 13, 2008
    I picked this up from someone on craigslist. Neither the sound or the picture work. Power light comes on but screen is black. Could this be a bulb? Or am i looking at something else totally different? Thanks
    Dan
Fuse is out on the signal pcb
Posted on Jun 02, 2008
Red LED at front of tv is flashing on and off, no sound or picture coming onto the tv.
Tries tv unplug,replug it back like about an hour later.For the tv resetting itself back to the factory setting,now tv should be working again.If still have the same problems,the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 18, 2011 | Samsung LN-S4051D 40 in. LCD Television
I have a Samsung 50" HDTV DLP TV that I purchased 10/12/2008. I turned the set on the other day and it would come on generate a normal picture then power itself off. I unplugged the set for a few hours...
Lamp could still be going out they only last for 5,000 hrs some 8,000 playing hours.
Check the Lamp Fan if it stops running when Lamp turns on set will turn OFF.
But if you have never replaced Lamp Problem will be the Lamp Mats Has them for $99.00
1-800-628-1118
Oct 23, 2010 | Samsung SP50L3HX 50" DLP TV
Picture no sound
Reset the tv back to factory setting,by unplug,repluging it an hour later.Go in ur tv AUDIO setting reset it,now it back to factory setting,Should work,not than the tv Tuner board recieve the broscast signal boad is have problem must br replaced.
Jun 02, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Set will often have problems starting back up
you have a high voltage arching problem. the crt has about 33000. (thirty three thousand) volts on it. the anode lead is arching to the chassis(ground) around the crt(picture tube). the anode lead is the big red wire on the very top of back of crt. with the back off, you will see the big red wire and it will have a suction cup about 4 inches round connecting to picture tube. unplug. silicone around suction cup. let dry for 24 hours. enjoy. you might get a little shocked even when unplugged, but wont hurt you.
Nov 12, 2009 | RCA MM36100 36" TV
TV randomly shuts off and does not come back on unless you unplug it and replug it back in
This is likely caused by voltage leakage which happens due to a build up of dust and other contaminants that make its way into the inside of the set.
1. Unplug the set for 4 hours or overnight and leave unplugged.
2. Remove the back cover and vacuum off any excessive dust and dirt.
3. Using a damp cloth, clean around the neck of the picture tube where the large wire connects (this is the main power wire). Wait about 10 minutes and then re-wipe.
You may find that you need to repeat the process a number of times before the problem will be fixed entirely.
Zenith TV troubleshooting
Sep 10, 2009 | Zenith Z19A11S TV
Picture goes off
A temporary solution is to unplug the TV for a few minutes, remove static from the glass with your hand. It is important to unplug rather than turn off. If you have a degauss button you can also press that before unplugging. Wait several minutes or an hour. Then plug it back in. If you have Picture in Picture it may be an issue with that and to permanently solve may need a repair person. The unplugging may get you by for a few days at a time. That's at least better than an hour.
Mar 13, 2009 | Fisher PC-32S90 TV
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Dec 11, 2007 | Toshiba 43A61 43" Rear Projection...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Hitachi 53SWX12B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
