Question about Kenmore 16812 Washer
Can i use my kenmore washer when the brake needs replaced
  • 347 Answers
You can use it ,but if the brake is bad the tub will try to spin while agitating and it may not clean as well as designed to. But their will be no additional damaged caused
Posted on Oct 14, 2010
  • the washer want spin
Posted on Oct 19, 2010
Kenmore Top load Washer machine, Model# 110.22902100 is making making loud noise (rubbing perhaps) at the end of spin cycle. What could be possible cause of this....?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022902100/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Assuming that the springs are OK and that the vibration pads are in place and not worn, (See the Sears diagram or the following Whirlpool Service manual)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
the problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum. If you have a spray can of silicone spray with a long nozell (Like on a can of WD-40) you may not need to pull the motor, pump etc.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same. Whirlpool (and Sears) have replacement brake pad / spring sets.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Jan 04, 2011 | Kenmore 22422 Top Load Washer
I have a Kenmore 70 series washer that vibrates and makes a huge amount of noise at the end of each spin cycle. Any ideas?
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It's not as difficult as it sounds.
Dec 18, 2010 | Kenmore Washing Machines
I have a Kenmore 600 model 110.28622700 that sounds terrible after it quits spinning. It is NOT out of balance.It is a loud thumping sound as it slows down @ the end of the spin cycle. What is it??
This assumes that you have a KENMORE top load, direct drive, neutral drain washers are made Whirlpool.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.28622700&pathTaken=partSearch
The problem points to the brake.
Whirlpool has a replacement brake lining kit if you need it.
Apr 07, 2010 | Kenmore 24922 Top Load Washer
At end of spin cycle the drum doesn't stop immediately; Instead it takes about 4 seconds and has loud noise like airplane during this time...
(See the following Whirlpool /Kenmore Service manual)
Over time, the brake shoes can wear or the springs can get weaker or break.
Following is the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
Whirlpool has replacement brake shoes and springs.
Mar 29, 2010 | Kenmore 25842 Top Load Washer
I need help replacing my switch lid on my Kenmore 70 Series mod. # 110-22722100 Washer. Can anyone help me with this??
if you have a gray switch than you nead to bypass the switch.if you replace the switch it will brake again.you do not nead a door switch.
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Washer all over the place.
In addition to the springs, I'd check the suspension plate and base assembly pads. These are also used to keep the washer from walking.
See the Whirlpool / Kenmore installation and maintenance manual for these washers.
When we took ours apart to work on the transmission, we broke one of these and the washer walked all over the place.
$10.00 for a replacement set solved the problem.
If you removed the drive tube to fix the brake, make sure that the two tabs on the drive tube fit into the slots in the basket drive block.
Oct 05, 2009 | Kenmore 23822 Top Load Washer
I have a top loading washer model #4420716...it will spin but make very loud noise I am wondering if a belt or something broke...it sounds like the basket is hitting the sides of the washer.
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Check and let me know.
Thanks.
Jun 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine 82110 - Loud Noise
Mar 31, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 16812 Washer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
