Question about Amana AFD2535DES French Door Refrigerator
How can i roll the refrigerator out to vacumm the coils?
    President:
  • 1,891 Answers
Open the freezer and when the drawer stops you can pull from the door and it should roll . make sure that a foor is not set in front to prevent roll out .. mm . different ways to get any frig out depends on the floor its on . wood is easy carpet not so easy and tile has grouves and make's it hard. so just use you head . i use nylon slides to help an carpet and to protect wood floors . some dent easly ....
Posted on Oct 14, 2010
2005 gmc envoy runing rough po302 i replace plugs and "2 coil now po300 runs rough
have you replaced the fuel filter. also check the battery new cars use a lot of power and that could cause a random misfire code. if those are all good then check for a vacumm leak. you can do that with carb cleaner by running the vehicle and spraying around the intake manifold or vacumm lines and listen for a change in the motor
Apr 04, 2013 | GMC Cars & Trucks
Why is vacuum condenser light blinking
this is usually a leak in the evap coil,if it's under 12 years old the coil is still under warranty.sub zero is a great machine,the only problem is that the evap coil behind the back wall in the fridge section leaks or a hole develops.the freon leaks out and the fridge section will continue to get warmer,the vacumm coil lite will come on.i've seen this happen to some machines that are 3 years old it happens.you need to get a tech in,he'll recover the gas,evacuate it,replace the coil and add new freon in,if it's under warranty it will be 650 to 750,or if not under warranty 11 to 12 hundred dollars to repair.
Dec 29, 2011 | Sub-Zero 650 / O Bottom Freezer...
Condenser fan is not running. coils are hot and the compressor sounds like its working. the evaporator fan is working. The refrigerator is not as cold as it should be
Spin the fan by hand and see if that helps. The condensor fan is causing head pressure to rise and the compressor is fighting it. This in turn will affect the cooling effiviency.Vacuum the cobwebs and dirt that has accumulated and vacumm the fan motor yhrough the vent holes on its end opposit the blades. Spin the fan blades with a pencil to protect your fingers. If the fan still won't turn, it may need to be replaced Good Luck_Ned_
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Bad smell from underneath side-by-side Jenn Air fridge - how to access and clean out drain pan?
drain pans are no longer removable. to clean. can remove back panel or btm frt kickplate and look for pan. spray lysol down their and clean out the coils.the only reason it should smell is if anything spoiled in ref. and got into drain system. you can try and vacumm up whats in the pan but you will have little room. unplug ref from wall before you go poking around.
Sep 19, 2009 | Jenn-Air JCD2389G Side by Side...
The ice maker only makes 7 or 8 cubes and then stops making cubes.
Check the condensor coils ( the roll of coils in back of the fridge ) to make sure they are clean of dust...etc . Try lowering the freezer temperature slightly colder also .
Jul 10, 2009 | GE GSS25SGSSS Stainless Steel Side by Side...
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
Water leaking from bottom of kenmore side by side fridge.
THE FREEZER MAY BE FROZEN UNDERNEATH THE COILS. UNPLUG THE KENMORE AND GET A VACUMM CLEANER OR A SHOP VAC AND CLEAN THE COILS ON THE BOTTOM OF THE FRIDGE. AFTER THAT REMOVE ALL ITEMS FROM THE FREEZER AND USE A SCREW DRIVER TO REMOVE THE PANELS FROM THE INSIDE OF THE FREEZER TO LOCATE THE COILS (INSIDE) THEY MAY NEED TO BE DEFROSTED DUE TO THE LENT BUILD-UP ON THE (UNDERSIDE) BOTTOM OF THE FRIDGE... HOPE THIS HELPS
Jun 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
138 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
