Question about Kohler Home
My single arm Kohler shower valve drips from the shower head after being shut off for several hours. I have replaced the cartrige attached to the handle and the O rings at the back of the mixer unit. It still drips.
3 Suggested Answers
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
SOURCE: I have a single handle
you need to clean out the diverter before replaceing with new washers and seats.
Posted on Oct 30, 2010
How do I fix a dripping shower head in a stand-alone shower? We have already tried to replace the valve assembly but it still leaks.
Obviously this is a leak in the valve. They are no fun to work on. Some of the higher end models of valve have seats that you can change and along with the ball and other hardware, that should stop the leak. If not you will have to replace the whole valve assembly.
Dec 16, 2015 | Home
I have a steam shower cubicle and when the water is switched off it still drips from the shower head,it only stops if I run the hot water tap in the sink
Most likely the issue is the unit is not isolating the water when turned off. Inside the shower valve will be an on off valve that will likely look like thus 06a0e29a-a81e-4b1d-b746-6d8bf0394774.jpg if you can locate one of these and replace your dripping will be resolved. Alternatively if this is only dripping from the larger monsoon in the roof, this can drip for a while after use as it holds a fair bit of water.
Can also try selecting one of the other features when not in use such as he back massage jets ( if you have a 3 dial valve) if it still drips then the problem will almost certainly be a replacement on/off valve
Steam Shower Parts Spares
Jan 04, 2014 | Kohler K-1698-G Brushed Chrome Tandem...
Drips from shower head when in off position
Hi.
Deltas can be either cartridge type or cup and spring type; both are easy to repair. Try to operate the valve several times full range and then shut off. If the problem is caused by a bit of trash in the valve assembly, you may be able to work it out with the problem solved. I have gotten away with this on several occasions.
If that doesn't work, cut off the water to the shower at source block valves, if you have them. It nay be necessary to shut off the water to the house at the water meter. Drain down the house side of the water supply at the lowest point, usually an outside faucet or flush the toilet, Gain access to the valve inner parts by removing the handle (single handle faucets usually are attached with an allen screw on the underside of the handle, removing the chrome escutcheon and the wall cover plate. Slowly and carefully remove the inner piece and look for any apparent damage. If yours is of the cartridge type, it is easier to simply replace the cartridge. If it is the cup and spring type, repairs involve changing out the bad components. I suggest that you place all of the parts that you take out in a plastic baggie and carry them with you to the parts store, or one of the big box stores, where parts should be available. Reassembly will be in the reverse order of the tear down.
Best regards,
--W/D--
Jan 13, 2011 | Delta & Single Handle Shower Faucet
One shower head inn 3head automatic system does not spray, just drips.
there could be dirt in the shower head or the two way divertor valve. i would remove the shower head first.
Dec 29, 2010 | Kohler Plumbing
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Sep 25, 2009 | Delta & Single Handle Shower Faucet
SHOWER HEAD DRIP
the problem is in the shower fitting the part with the handle ,depends on who made it but you replace washers or a cartridge some times easy some times not
Aug 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Mar 04, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Leaky posi temp shower valve
coming from the uk it sounds that when you mention it leaks at night its a possibility thats when the water pressure increases & the valve starts to drip?
i know its not a solution but it may help you understand why its dripping at night.
Also the seals might be damaged in which case thats why its dripping check them for damage. make sure when you put the new cartridge in that you put some silicone grease around the seals as this helps the insertion & helps protect the seals from damage.
Kindly
Richie
Dec 15, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
162 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
