Question about Remington Precision HC-815 Hair Trimmer
I also need a new 1/8" and 3/4" guards.
Anybody know where we can these accessories?
  • JonnyClipper Jun 02, 2008
    Thanks Jerry, I like the direction you're going with that. However, the website you provided took me to Remington firearm (aka rifle) location. But I get the gist. I'll find the closest support office / retail outlet for my hair clipper accessories.
    Genius:
  • 1,689 Answers
The link below is your only source. Find out from them if there are any authorized dealers in your area. Most likely you can buy spare parts directly from them.
http://www.remington.com/support/parts/
Jerry G.
Posted on Jun 02, 2008
  • Jerry Greenberg
    Jerry Greenberg Jun 02, 2008
    Sorry about that! I meant for Remington appliances!
    But, anyways, you got the idea of how to find the parts.
    For anything you buy or own, if the item is a little expensive and you would like to be able to service it, always buy name brands that there is available support. This way, you can find parts and service for it.
    Jerry Greenberg
Need a new guard
I called Norelco and they sent me one for free
Dec 31, 2012 | Philips Norelco Qc5530/40 Do-it-yoursel...
Need to change out the water pump in a 2002 monte carlo ss has a 3.4 in it how do i take the old one out and put the new one in.
  1. Drain the cooling system.
  2. Remove or disconnect the following:
    Negative battery cable Accessory drive belt guard Water pump pulley bolts, loosen Accessory drive belt Water pump pulley Water pump
    Fig. Water pump assembly mounting-3.1L and 3.4L engines
To install:
  1. Install or connect the following:
    Water pump with a new gasket and torque the bolts to 89 inch lbs. (10 Nm) Water pump pulley and torque the bolts to 18 ft. lbs. (25 Nm) Accessory drive belt Drive belt guard
  2. Fill the cooling system.
  3. Start the engine and check for leaks, repair if necessary.
Jul 21, 2011 | Chevrolet Chevy Cars & Trucks
I have a 2003 Yamaha v star silverado 1100 When looking at the back of the front forks you can see a manufactured indention on the back side of the right tube (it actually looks to be a cover or guard over...
Have you tried to add some puddy epoxy to the cover or guard over the right tube so that a hard right turn will not hit the key and shut the bike off?
Or is the problem that the cover or guard is hitting the key directly?
Jul 03, 2010 | 2005 Yamaha V Star 1100 Silverado
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
I am looking for a Network Workstation with all accessories needed for Video Mangement System for CCTV camera Video Surveillance
Go to cctv Video Guard
These guys have great deals. Talk to the person on the website. They are there 24x7. They will give discounts on older models, help you plan and ship within 2 working days.
In case you need real security Guards to watch the cctv 24x7 over the internet for $1/day goto sms Video Guard
Cheers
TeaCii
Mar 14, 2010 | LaCie Ethernet Disk (301298U) 2000 GB...
I need to re-attach the blade guard spring. Could you please describe how this could be done.
first remove the blade and make sure tool unplugged, one end of the spring goes into a slot in the housing and the other into a hole in the lower guard. make sure guard retracts completely (you might have to use some WD40 or similar product) Let me know if you still need help
Dec 13, 2009 | Makita 7 1/4" Circular Saw 5007NB
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Need ac adapter for Compaq projector
Hi Tech Lady , greetings !!
Your projector has a "Multimedia Adapter" .
You can purchase the adapter from www.trademoon.com or directly from HP.
Trademoon is a discount supplier of new and refurbished Compaq and HP parts.You can call them at 97
2-682-5000 or log on to www.trademoon.com
Or you can also call HP/Compaq at 1-800-474-6836 and say "SPAREs"
The specifications of your adapter is :
Power Consumption 5 Watts (standby)/185 Watts (full power)
Power supply 90V to 255V (auto switching): warm restrike after 45 seconds
Goodluck :)
Jun 04, 2008 | Compaq AC Adapter Projector Lamp
Remington Precision HC-815 Hair Trimmer Logo
496 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
