Question about NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair
All lights blinking rapidly - NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair
    Novelist:
    Champion:
  • 232 Answers
The number of blinking lights indicate the problem. Visit this site to determine the cause:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try pushing the manual brake release levers all the way to the floor (with the power chair turned off) then back up until they pop into place then turn the power chair back on. If you continue to have a problem, contact Hoveround, they are good at trouble shooting over the phone.
Posted on Oct 20, 2010
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
What does theblue light mean when its blinking
the steady, blinking blue light means it is working. If the light blinks quickly, ususally 3 times, then it is either turning itself off or turning itself on. if you're getting a steady blink, try holding the button down long enough for it to flash rapidly 3 times in succession. after that, it should blink no more, because you have just turned it off. Want to turn it back on? hold the same button down until it flashes rapidly 3 times again, and you have just turned it back on.
Jan 23, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
'05 Dodge Caravan 33kmi. right blinker has failed.It makes a rapid blinking sound but only rapidly blinks in the front not the back. Can I replace the flasher or is it a job for a mechanic? Thanks, A. Tahl...
Rapid blinking is usually caused by a failed bulb. The rear light not blinking should be a good place to start looking. Replace the rear bulb and both should be back to normal.
Dec 16, 2009 | 2005 Dodge Caravan
My internet light is blinking rapidly and
Your internet light will blink. It will blink at least 20 megs per day, without any use. That is normal, it is doing more it measn someone is using your wireless connection.
Nov 23, 2009 | Linksys Wireless-G WRT54G Router
How do you set the garage door opener for a 2004 toyota 4runner LTD?
You hold the remote close to the three buttons on the vehicle. You choose which button you want the remote to transmit to, and you hold it down. With your other hand, depress the garage door remote opener, and hold it very close to the 3-button assembly. Wait for the red L.E.D. light to blink slowly. If it does not blink slow, continue moving the remote around, until it does blink slow. When it starts to blink slowly, stop moving the remote around. Wait until the light starts blinking rapidly. When the light blinks rapidly, the process is complete.
Oct 28, 2009 | 2004 Toyota 4Runner
98 nissan altima front left blinker does not work when headlights are on, works when headlights are off but blinks rapidly ,left rear blinker works when headlights are on or off but blinks rapidly also
the rapid blink is because there is a bulb outage some where, Pull Over turn on left Blinker Get out of your car look at the front left blinker hen walk to the rear of your car and look at the left rear Blinker light then do the same for the right side blinkers if all are working rapidly your left right switch is bad
Jul 09, 2009 | Nissan Altima Cars & Trucks
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Flasher
When 1 is inop and the other rapidly blinks that generally means a bad ground to the front light if you can't find it just attach another ground wire to the bulb socket and see if the light blinks normal.
May 27, 2008 | 2000 Mitsubishi Diamante
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair Logo
664 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
