Were can I get a AC-DC converter and AC power cord for my Eee Pc 1000HD computer.
    President:
  • 1,932 Answers
Basically you need full adapter for your laptop right? Can you tell the in put required for the laptop?
Thank You
Posted on Oct 14, 2010
Asus eee pc 1000hd wont turn on at all
have you check the power lead is ok, and have you check the fuse in the plug.
are you getting any lights on the laptop?
Apr 14, 2014 | ASUS Eee PC 1000HD Notebook
Battery led flashing
Try another cord/charger with the EXACT same power specs. If it still doesn't charge, Replace battery with a genuine Asus battery.
Mar 18, 2013 | ASUS Eee PC 1000HD Notebook
Broken power plugin port
The power plug in port you refer to is the DC Power Jack.
The AC adapter (Charger) converts AC electricity into DC electricity.
DC electricity has two poles. Positive, and Negative.
(Just like on a D cell flashlight battery)
The center pin of the DC Power Jack is the Positive connection.
The outer metal spring-like pieces, on the inside of the cylindrical shape surrounding the center pin, are the Negative connection.
(The pieces of spring-like metal, all connect to the Negative connection in the DC Power Jack)
Example of a replacement DC Power Jack, for the Asus Eee PC 1005HA Netbook,
http://www.batterysupport.com/asus-eee-pc-1005ha-jack-p-303527.html
[ Note*
Cannot agree with the replacement instructions they offer, at the bottom of the page.
Not everyone has access to a hot-air gun. A 25 Watt soldering iron, and Desoldering Braid, is better, and more easily accessed ]
A few articles dealing with replacement of a DC Power Jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Observe Anti-Static Precautions. Buy, and use an ESD wrist strap.
Electro Static Discharge.
(Average cost is from $3 to $6. Connect the alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If you wish to proceed in replacing your DC Power Jack, and need guidance, post back in a Comment.
Regards,
joecoolvette
Dec 01, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My Eee PC 1000H is turn on but the display is off. i try to turn off by pressing the power button but nothing happen. when i plug the AC/DC power cord, eee pc is turning on but lcd still black
Welcome to FixYa!
It seems that you are having problem with the LCD on the laptop. This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
May 24, 2011 | ASUS Eee PC 1000H Laptop
I have an ASUS eee netbook. Recently the power cord hasn't been connecting well to the computer and now it doesn't even register. It's plugged in but isn't charging. Is it the cord or the laptop?
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
Nov 30, 2010 | ASUS Computers & Internet
My eee pc 1000hd will not start up. Can and will you help?
What is the Exact Problem?
You can just make sure Power connector sould be connected and Switch ON.
You can disconnect the Battery and reconnect it,
It should be work.
Sep 27, 2010 | ASUS Eee PC 1000HD Notebook
I have no display in ASUS Eee PC 1000H PC Notebook but power and light is there
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 16, 2010 | ASUS Eee PC 1000H Laptop
Need AC 15V 1.1A power cord for HK195 speakers
Hey, I was in the same situation. I tried a 9V DC (yes DC) converter I had and it works perfect. You can use a DC on a AC input - never the other way around. Due to insufficient power I get distortion at very high volumes... but I never play that high so I'm good..
Oct 07, 2009 | Harman Kardon HK206 Computer Speakers
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
AC-DC power converter for Samsung SyncMaster 191T Flat Panel Monitor
According to all the specifications on the web that has built in power. You should just need a standard PC power cable.
Maybe the SN on the monitor would help to locate what you need.
Oct 10, 2007 | Samsung SyncMaster 940BE 19" LCD Monitor
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
