Question about HP Photosmart 2410 All-In-One InkJet Printer
HP Photosmart 2410
My printer 2410 is freezing up after a power outage. Will not restart, hour glass displays. please help
  • spaz1 Jun 06, 2008
    cannot get ink cartridge in
Por favor me pueden ayudar con los drivers de esta impresora les quedare eternamente agradecidos mi correo es dismanort@hotmail.com
Posted on Jun 20, 2008
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
My HP 2410 Photosmart printer is making a clicking nose on start up. In the past I was instructed to unplug it and everything attached to it, including the computer, for 15-30 minutes and it would reset...
Uninstall the printer completely starting from the software.
Go to Start Menu, Control Panel, Add/Remove Programs, select the HP Photosmart software and remove it.
Then, go to Start Menu, Control Panel, Device Manager (usually under Administrative Tools/Computer Management).
Select under "Printers", the HP Photosmart 2410 All-in-One InkJet Printer and remove it.
Restart your computer and follow the instructions from your HP manual to setup your printer again.
Apr 06, 2010 | HP Photosmart 2410 All-In-One InkJet...
We had a brief power outage--now prinker knunks
In all probability that Power Outage caused a massive Spike or Surge on your power line. This has affected this unit. It doesn't take much to cause this type of thing and is quite common. It may be repairable, however these days buying a new one is often a better option. If you do go the repair route, go to a reputable place, & please ensure you get a firm "Quote" not an "Estimate" for repair.
Jan 20, 2010 | HP Photosmart 2410 All-In-One InkJet...
Power cable
Give cablestogo.com a try ...
Jun 12, 2009 | HP PSC 2410 All-In-One InkJet Printer
Flashing green light and hour glass - performs no functions
Please perform the steps given below and check the functionality.
Bypass the surge protector
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet and see if the message still appears.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
May 26, 2009 | HP Photosmart 2410 All-In-One InkJet...
Hp 2410 just clicking
When you power on the printer.
See if the scanner light move to the right and then keep on clicking.
If this happen, the scanner head is unable to find home position.
You will have to clean the strip under the glass.
If this only start to happen recently, you could unplug the printer and wait 1 hour.
Replug in the printer will at times stop the clicking.
You can go to http://h10025.www1.hp.com
Enter c00553775 into the search block.
Click on Hp All in one how to clean scanner glass.
This will bring you to the HP document.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart all-in-one
scanner replacement is needed as this cannot be repaired,the lower printer part is perfect just the scanner parts needs replacement.it is also costly to get replaced.
Sep 29, 2008 | HP PSC 2410 All-In-One InkJet Printer
Light flashing on 2410
Unplug the printer and leave it unplugged overnight (or just a few hours), then plug it back in.
Sep 15, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp alll in one model # PSC 2410 photosmart. Printer makes sound as if printing then stops and timer clock stays on. . tried again after shutying it off.Same problem. please help
I have a photosmart 2410 also. I found if i unplug the printer for 15 min. then plug it in, it clears the hour glass and restores function.
Jun 06, 2008 | HP Office Equipment & Supplies
Machine won't boot up
I found this suggestion on line and it worked. After turning on my hp psc 2410 photosmart all in one, it just started making a peculiar sound and wouldn't boot up. It was useless. What I did to correct the problem (as per suggestion from cdpena@sbcglobal.net) was to hold the cancel button down before I turned the printer on and hold it down through the start up process. The thing works now. The problem may have been caused by a power outage. Thanks cdpena@sbcglobal.net. I almost bought another printer.
Sep 04, 2006 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart 2410 All-In-One InkJet Printer Logo
97 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
