Question about Acer Aspire 5315 Notebook
Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
  • 340 Answers
How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
courtesy of Microsoft.com
Posted on Oct 14, 2010
Asus laptop dropped and now gives
The drop probably damaged your hard drive
Nov 26, 2012 | Acer Aspire 5610 Notebook
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so...
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on
the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical
support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 25, 2010 | Acer Aspire One PC Notebook
Cant start netbook acer zg8
usually means hard drive is bad if there's any data on this computer u HAVE to have leave it off and take it to a com repair shop or plug the hard drive in to another pc that works and see if you can copy any data off. youll probably need a ide to usb, sata to usb or an extra sata cable/connector on the mobo and power connection
Apr 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
MY LAPTOP WONT GO TO THE START MENU
you need to click ctrl+alt+del hit cancel and it will work :)
Jan 17, 2010 | Toshiba Satellite M55-S135 Notebook
My laptop wont start.
your operating system was corrupted you need to re-install or repair install your O.S...
Oct 12, 2009 | Acer Computers & Internet
Disk error
Replace the HDD at service center. Seems to be bad disk.
Sep 16, 2009 | CMB T43 750 Notebook
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
Start up problem
hi steve,
can you get into the BIOS?
if so, would u make sure the boot orders are following:
1st. boot from hard drive,
2nd, cd rom
3rd, floppy,
4th, network adaptor?
save changes and try restart.
i hope you do have OS installed.
if not change 2nd part to 1st, and 1st to 2nd.
i have gotten the same error with my laptop. my computer was trying to load window from network, through network adapter.
hope this information helps.
Dec 21, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Acer Aspire 5315 Notebook Logo
227 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
