Question about Dell 922 All-In-One InkJet Printer
Paper Jam Error
The printer keeps showing a message that there is a paper jam however this is not the case. Any suggestions on what to do?
  • sk8rgrl1018 Jun 26, 2008
    I have the Dell 922 All In One Printer and I keep getting a paper jam error msg when there is no paper jam. When turning off the printer and restarting...the rollers just keep rolling for a few seconds then it gives me the error msg. I tried your solution of moving that little black bracket off of the center plastic piece and down into the gap...but that did not correct the problem.
    Any help is greatly appreciated !! Thanks!
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver and now everthing works fine!
Posted on Jun 23, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
Printer keeps saying it has a paper jam and to remove the jam from the back. There is nothing there! I think it just wants me to open and close the rear door, but that only fixes it sometimes. How do I...
Nov 22, 2010 | Ricoh Aficio CL1000N Printer
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
May 11, 2009 | Office Equipment & Supplies
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP Laserjet 1020: False paper jam
Hp false paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 25, 2007 | Office Equipment & Supplies
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
