There is a loud "knocking" noise during the Spin cycle - it doesn't start until it's near top speed but it sounds like it's seconds away from exploding!
  • 2 more comments
  • joelizacn Oct 14, 2010
    Thanks so much for your response! It's gotta be something like that. . . we can't really lift the tub but it seems loose from front to back. Is this an easy fix? My hubby's pretty handy. Or should I call a tech? Not too many options in Show Low for Good appliance repair. . . =/
    I can see 4 shocks - but the outer tub is barely moving when this noise is racketing away. =)
    The noise definitely seems to be originating at the back in the middle of the tub and sounds like someone is beating it with a bat!
    Thanks so much for your response! It's gotta be something like that. . . we can't really lift the tub but it seems loose from front to back. Is this an easy fix? My hubby's pretty handy. Or should I call a tech? Not too many options in Show Low for Good appliance repair. . . =/ I can see 4 shocks - but the outer tub is barely moving when this noise is racketing away. =) The noise definitely seems to be originating at the back in the middle of the tub and sounds like someone is beating it with a bat!
  • joelizacn Oct 17, 2010
    It is a Kenmore frontload HE4t. . . Mod#110.45996400
    Thanks!
  • joelizacn Nov 16, 2010
    SO, it ended up being a bracket on the back of the metal tub was completely cracked and while it was spinning it was knocking against the plastic tub and ended up scraping a groove into the plastic tub and there were little plastic shavings everywhere including underneath the seal around the tub by the door. Sears wanted $1400 to replace the metal and plastic tub - they said the "Lifetime" Warranty on the parts is only to the original owner. We ended up buying the parts for $450 and my amazing Hubby did the work.
  • Washing Mach... Master
  • 713 Answers
Hi Joel just read your posting.Now could you please supply me with the make and model number of your machine and if it is a top or front loader.Then I can accurately diagnose the fault on your machine.Looking forward to your reply.
Posted on Oct 14, 2010
  • luisa_sgro Oct 14, 2010
    Hi just read your posting to the other tech and I am now sure it is the main bearings and main seal on your machine that is faulty. If you could supply the make and model number of your machine I can help you further. Looking forward to your reply.
  • luisa_sgro Oct 17, 2010
    Hi just read your posting.1st thing to do is to open the door and grab the steel bowl that the clothes go into.Now see if it has any movement on the bearings.Your husband can probably tell that the bowl has faulty bearings by gently rocking the bowl from side to side for movement.By the way please do not mistake the movement of the tank and bowl on the suspension rods for movement in the main bearings.Also turn the steel drum by hand and if you hear the bearings then the main seal and bearings need to be replaced.Please reply on what you find and I can guide you from there.Looking forward to your reply.
    President:
  • 1,891 Answers
Last one that i cked like you stated / the h/o said it sounded like it had a flat tire . what we found is the inner tub had come loose from it drive . his unit was a crosley / kenmore/ g e all these machined are built a like . you can reach inside and lift the tub and if it's loose you know now whats causing the noise . other things are they have shock and they some times come loose . . .. hope this helps mm
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Loud dry sounding spin cycle
cabrio and calypso have some issues with either main bearing problems or brake drive issues, either or this is an expensive fix, so if you have an extended wty, call your service provider, if not, just replace it, repair most likely in excess of 600.
Jun 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Kenmore 90 series - clicking during slugish spinning cycle
try your unit on a outlet by it self ,,nothing can be on this line,,sounds like weak ampage,,this machine needs 15 amps line by it self...
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Electrical clicking, motor lurching sound during spin cycle
its not your unit it your electricity,,you have to many thing on 1 breaker..the unit is asking for power ,,a washing machine needs a breaker of 15 amps by its self..put the unit on a oulet by its self..with no other load
Dec 26, 2008 | Kenmore 15864/15862 Top Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
