We have a Centrix CTW 60519 Autowasher. The machine is not spinning properly, leaving clothes very wet. How can we locate a spin cycle?
  • gail_martin_ Oct 14, 2010
    Hi Luisa, The machine is working perfectly. It agitates and the moter can be heard. The instruction manual has been lost. How do we get it to spin manually, when we handwash items? What button? How do you select a spin cycle?
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the motor is spinning with low RPM.
Just to be sure of the speed control system please check ;
If the spin section is having a secondary speed control motor then it is not engaging.
If this is a servo driven motor then the electronics is not working well and must be checked.
If this has a geared drive the mechanism may not be engaging to the motor.
If there is no extra speed control or drive then the capacitor to the motor may be faulty reducing the motion.
Check also the belt if this is a belt driven mechanism., and also the friction in the drive.
Please try these tips out and respond.
Posted on Oct 15, 2010
  • 713 Answers
Hi Gail just read your posting.There could be a few reasons for the machine not spinning.Does the machine agitate?Can you hear the motor turn when it is spinning?Remove the back cover of the machine by undoing the 4 screws holding the cover to the back of the machine.Now select a spin cycle and watch the belt on the motor and drive pulley and see if it turns quickly.Do not put your hands on any wires or pulleys as you might have an accident,So please be careful.Please reply and let me know if the motor and belt is turning on spin and if the machine washes.Looking forward to your reply.
Posted on Oct 14, 2010
  • luisa_sgro Oct 16, 2010
    Hi Gail to select spin on you machine you need to 1st push power on, then push the WASH button until the 3 lights that indicate the minutes above the wash button are NOT lit.Do the same to the RINSE button.Then the only lights that are on to indicate minutes remaining are above the SPIN button.Noe push the spin button and select the amount of time you would like the machine to spin and the push the START button.Hope this helps and please reply for further help and to let me now how you got on.Looking forward to your reply.
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
I own a Kenmore washer Model 110.22722100. The last couple of weeks, it leaves the clothes wet. It drains like it is supposed to and spins. What is causing this to happen?
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Here is the part you will need.
Nov 28, 2010 | Kenmore Washing Machines
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Will not spin with load of wet clothes but will spin when empty
clutch not engaging properly perhaps the belt is streched. Timing module not grounded properly, faulty module, motor circuit bad (brushes worn)
Nov 22, 2009 | Washing Machines
Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Only spins slow
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 06, 2009 | Washing Machines
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
1999 Maytag Neptune front loader
Have you replaced your 12002535 door latch wax motor if you have a MAH3000, MAH4000, MAH5500A or the 2000 stacker? These wax motors will eventually fail on every Neptune shipped. When the wax motor fails the upper machine control board be damaged and you will lose your spin function which leaves your clothes soaking wet. There is a website that offers a repair kit to see if your control board is useable again. Don't keep starting machine because you might cause further damage to control board and the motor control board located near the floor until you see if R11 is burnt on the upper machine control board located behind the timer.
See www.neptunewaxmotor.com for more details and step-by-step disassembly photos.
Sep 21, 2008 | Washing Machines
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
