Question about Refrigerators
Where to find old parts such as defrost timer for Sears coldspot 2354 Upright freezer 19.5 cuft
    President:
  • 1,891 Answers
On the timer there will be a part # it should be easy with it to locate replacement . with a complete model # I could give you the info . mm
Posted on Oct 14, 2010
Why freezer doesnt turn on
If it is a frost free model, the defrost timer could be stalled in defrost. Other than that the thermostat could be the problem.
Jul 16, 2014 | Kenmore Refrigerator Freezer Shelf 13 5/8...
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
Water drips from the freezer into the fridge.Upon disassemble, there is ice buildup under the coils. kenmore coldspot model #71184101
The defrost timer or the defrost heater element has probably failed. Go to the link below and enter your exact model number; you should find a line-drawing illustration and parts list for your fridge that you can use to locate these items and normally also determine how to remove or install them:
Sears PartsDirect
Apr 08, 2011 | Kenmore 52632 / 52634 / 52639 Side by Side...
I need to replace the thermostat on my very old Kenmore Coldspot Upright Freezer, model 106628420. I have no owners manual and there is not one to be found. I would like any help possible. Thank you so...
Not that this diagram is a lot of help, but I did find this on a Sears website:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Freezer-Parts/Model-106628420/0582/0142000?sid=PDVertical
Nov 10, 2010 | Kenmore Freezers
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
I have an old Searsd Coldspot upright freezer, Thr
on the side of both defrost controls is a diagram black is normally power white is normally nuetral wire the black wire will go to the center of the switchs defrost heater
will be on one side compressor to the other white to the clock moter green was hooked to the metal case if you have a mutitester the clock moter will have constant continuity even after the timer has been turned till it clicks the heater will go on the contacts that have continuity for the shortest amount of time
on the back of most older units was a wiring diagram constant defrost has power even when t-stat is set to off
cumulative the defrost only has power when compressor is running the diagram on old defrost timer should be simaler to the diagram on the old defrost timer the lighter colered tab is normally white wire
hope you have a tester but if you are inclined hook up black and white only turn control till clicks when you have the black wire in the correct position the moter will run no matter where the control is turned
then find wire that starts compresser it will need to be placed on the switch that maintains contact the longest leaving the
heater wire to hook to the contact that stays closed for 20 to 30 minutes
most defrost controls wire the same be careful wiring is 120 volt
Dec 13, 2009 | Cell Phones
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
After freezer was moved not getting cold
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Jun 02, 2009 | Freezers
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Sears Kenmore ColdSpot Frostfree Frosting up/Not working
You have a defrost problem. You need to determine which one of the parts is faulty. The defrost timer on that model should be behind the kick plate in the center front underneath. If you turn the little knob by hand you will hear a load click when it gets to the defrost point and the unit should shut off. Check in the bottom of the freezer to listen for water sizzleing or for water running down. If it is the timer is not advancing and needs replaced. If not you will have to take the back off the inside of the freezer to see if it is the heater or the defrost thermostat. Unhook power before taking panel off or replacing any parts.
Apr 24, 2008 | Refrigerators
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
