Question about Sony Playstation 3 (PS3) Console
Does not show on tv i have treid holding the power button for 5 minutes
    Problem Solver:
  • 35 Answers
Bang with fist
Posted on Oct 14, 2010
My Netflix works up until I press OK, then screen goes black. Thankyou.
Restart the smart TV
Press and hold the power button on the TV remote control for 10 seconds to restart the TV.
If you restart the TV, try Netflix again.
If the TV does not restart, turn it on again and continue with the following troubleshooting steps.
Disconnect the TV from the power for at least 1 minute.
With the TV off, press and hold the power button on the TV for 5 seconds to unload it.
If you can not access the power button or your TV does not have it, leave the TV off for at least 3 minutes.
Reconnect the TV.
Turn on the tv.
Try Netflix again.
Aug 12, 2017 | Cars & Trucks
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
When turned on box will only show menus and will not play TV or recordings. It gives the impression that it is trying to play in the background
i have ATT Uverse. Any problems I have had are usually solved by resetting the box. Press and hold the power button on the box until it shuts off-usually 5 seconds or so. Wait 3-5 minutes and power on. It takes a bit to reset. If that doesn't work, unplug from power supply completely. Wait 3-5 minutes. Plug back in and power on. If that still doesn't help, call ATT. The can do remote reboot, but, you will lose all recordings stored.
Sep 29, 2014 | Televison & Video
My phone is stuck in on and off mode
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.try
Aug 17, 2009 | Apple iPhone 3G
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
TV does not recieve a remote
Hey, Have you tried to power cycle your remote? That may work, do the TV too. I'll give ya the steps, just follow them and you should be ok. I'll throw in a factory reset as well, but if you're not using a cable box you will have to run another auto scan. anyways start off by unplugging the TV and removing the batteries from the remote control. Let them both sit, you don't have to let the remote sit really, but I do for good measure. You have to let the TV sit for a minimum of 5 minutes. at the end of 5 minutes, you have to find the physical power button on the TV, this means NOT on the remote, but on the TV itself, you have to find this power button, and you have to hold it down for 1 solid minute. Again, any time you can do something extra for good measure, it can't hurt, so if you want to leave it unplugged for 10 minutes and hold the button for 2, go for it, it may help. After you're done with that, power cycle the remote control. Being that your remote seems to be haywire, go ahead and press every single button, this means channel up and down, even if they're on the same button, every one from the top to the bottom, 5 times with no batteries in it. Then hold down the power button on the remote for 30 seconds. Then replace the batteries, preferrably with new ones. This completes the power cycles for both the Remote control and the TV. Now, before plugging the TV back in, we have to do the factory reset. Again, hold the power button on the actual TV, and then, while holding down the power button, plug in the power cord, wait for a couple of seconds, and then release the power button. Wait for a moment, and then turn the TV on. This completes the factory reset.
The reason for all of this, is, power cycle the remote to drain it's capacitors and reset it, power cycle the TV incase the Remote sensor is affected by a static electricity build up. Factory reset incase any settings may have caused this. Hope this helps.
Jan 14, 2009 | Philips 50P8341 50" Rear Projection...
PIP will not go off.
Try unpluging the unit 5 min then pres and hold power button 10 seconds (this should reset ir!
Dec 13, 2008 | Sony FD Trinitron WEGA KV-32FS16 32" TV
TC-32LX85 only stay on 5 minutes.
Just found a solution to this problem (conveniently hidden on unlucky page 13 of the user manual). This means that your TV is in store mode... it refreshes every so often and changes to the different inputs to show store viewers the quality of different inputs.
First, go to Menu - Setup - Advanced Setup and make sure that the "Auto power on" is set to "No." Turn the TV off and unplug it. Plug it back in. Press and HOLD the power button on the TV (not the remote). Hold for 2-3 seconds or so... you'll hear a few clicks. Release the button, then press it. The first thing that pops up should be, "Select viewing environment." Make sure you select "Home." Continue with setup from there.
Voila!
-Zach-
Aug 22, 2008 | Televison & Video
Power, volume buttons
Is this on the remote or the buttons on the TV?
Aug 17, 2007 | RCA P46810LV 46" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
15 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
