Question about Guess Gc Diver Class 33503G1 Watch
On my gc watch manual it says pull pin to adjust time. the pin was very hard so i used a little force to pull it out. it word for a few times until i pulled the pin out. The watch stopped working and when i put the pin back in it still doesn't work. please help me.
  • 2501 Answers
SOURCE: No action when I pull the stem out to adjust time
There may be more than one "out" position.
Typically there are three positions 1) home 2) 1st adjusting position, 3) 2nd adjusting position.
If you haven't got the instructions, you can get a download from their web site, (Rolex.com). You go to the bottom of the screen and there is a menu. Select "downloads" and you will see a list of downloads, choose yours.
Posted on Feb 09, 2010
escapement
  • 2334 Answers
SOURCE: I can't pull the bezel out to change the time on
The bezel is metal ring surrounding the crystal. What you can not pull out is called CROWN. Unscrew it first and then pull out.
Posted on Mar 29, 2010
escapement
  • 2334 Answers
SOURCE: how do i adjust the date on my classic watch
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Posted on Jan 12, 2010
escapement
  • 2334 Answers
SOURCE: Movado 0604409 watchband adjust
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to remove or add links.. Rate me, please .
Posted on Apr 15, 2010
escapement
  • 2334 Answers
SOURCE: Skagen watch 105LTX band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 24, 2009
Cannot change the time
Gc Watches ' World Time - YouTube
? 2:53
https://www.youtube.com/watch?v=wxXNcb3VjYM
Sep 6, 2013 - Uploaded by Ceasmania Shop
Ceasmania este cel mai important site romanesc privind vanzarea ceasurilor si bijuteriilor marca Guess ...
Guess Gc Watches Sport Class XXL Review - YouTube
? 4:04
https://www.youtube.com/watch?v=hZxtnZFdjnA
May 8, 2013 - Uploaded by aBlogtoWatch.com
aBlogtoWatch watch review of the men's Gc (Guess Collection) Sport ... Show more ... Not like a cheap watch that gets scratches over time..
Guess Watch Guide on How To Adjust Time & Use ...
? 1:37
https://www.youtube.com/watch?v=V2FPk-6mD7g
Nov 29, 2011 - Uploaded by Jade Bryan Jardinico
Download Manual for all Guess Watches: ... Guess Watch Guide on How To Adjust Time & Use Stopwatch (W17540G2 50m ...Show more
[PDF]GUESS Watches
Jan 10, 2016 | Watches
Can the independent 12 hour hand be set and if so how?
You need to watch this video its given how to set time in Rolex watch's :
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
Hi i have just now received a new watch and i want to know how to set analog time. thanks, Abhishek
Hello.
To give a more precise instruction, I would need to know the watch model. But the standard procedure to set analog time would be to pull that little pin on the side of the watch, and than turn it. You should see the handles turn accordingly. Notice that the pin may have two different "heights", one for adjusting time, and one for adjusting the date.
Let me know if that solved it!
Mar 01, 2011 | Watches
SETTING DATE&TIME
i cant get a manual for this but watches have standard mechanical function so maybe this will do.
the center crown of the watch right side of the picture, loosen the crown. Be careful, some crown have a screw function so if your bulova has this don't force to pull it to prevent damage. if you have loosen the crown, check if can be turn it, if yes pull gently the crown, first pull date adjust,second pull time adjust.
This is the proper way to adjust you day and time.
say you want to adjust your watch to (date)10th (time)10:15am
adjust your date to 9th, then move your watch hands clockwise until the date change at 12oclock this is the evening time (PM) continue moving your watch hands until you reach 10:15am.
if your crown is a screw time remember to turn it close tightly for waterproofing.
Dec 13, 2010 | Accutron BULOVA men's 26B62
Job done!
Mar 24, 2009 | Skagen 355LGSC Wrist Watch
Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Dec 16, 2008 | Fossil Watches
Steinhausen watch adjustment?
To set time, you need to unscrew crown anti-clockwise direction if you have a screw-in crown watch. You need to softly and slowly pull the crown out a little bit. The best way to do this is to use first and second finger and use finger knuckle as a lever in order to pull the crown out with as little force as possible. You can feel a little "click"! Now you can set the time by turning it anti-clockwise. This would turn the minute-hour hands forward until you set the right time. When time is set, push the button back and screw the crown clockwise for a few rounds to ensure it is screwed back tight.
May 12, 2008 | Watches
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
How to adjust the band on a aquaswiss trax watch
Warning: This is if you don't have any professional watch tools. And I definitely recommend you taking it to a jeweler first.
That being said...
I was able to adjust my band by using a small nail and a pair of needle nose pliers...and Krazy Glue or Super Glue (last warning...you really should take it to pro)...
1. Push the any one of the pins that holds the wristband together until you see it protrude from the other side. While applying pressure to the pin, quickly grab it from the protruding side with the needle nose pliers and pull off the metal cap from the pin.
2. Note you will notice that the pins are actually 2 pieces! They are not screwed together and it makes for a pretty poor design since, one the pins are taken out and then replaced after taking out the appropriate links... they tend to get loose and you will lose that tiny metal cap that holds the pin in place.
3. A professional will have a clamp that is small enough to press these two pieces together. But even that is precarious. I strongly recommend that you carefully apply a drop of crazy glue on each end of the pin, after you are finished.
Final note: I was luck to have spare pins from the links I removed to replace the pin that worked out of its cap. That little sucker is lost to the watch gods. Have fun! Also... you can make final adjustments at the 3 pin location at the wristband release.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Dec 25, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Wrist band adjustment on a fossil watch
Just take a tiny little jewelery screw driver small enough to fit in the pin hole and tap it with anything that you can find. Then pull out other end. Look for arrows indicating which way to remove pin and go in that direction Some pins are like a hairpin and have a split at one end. Replace solid end first opposite of arrow direction. If there are arrows in both directions on the same link; like Fossil for instance, that means that it doesn't matter which direction the pins are removed or replaced. They are solid and they can go back either end first. It's easy. To get the pin in all the way I just used the little screw driver and tapped it in. Good luck.
Dec 24, 2007 | Fossil CH2331 Wrist Watch
Guess Gc Diver Class 33503G1 Watch Logo
1,119 people viewed this question
Top Guess Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Guess Watch Expert? Answer questions, earn points and help others
