Question about Kenmore Washing Machines
21062 - FL code - won't allow me to run any diagnostics; what part has failed?
    Problem Solver:
  • 87 Answers
Ur entire board has failed
Posted on Oct 14, 2010
Clear error code for kitchen aid kuds01 fl
Use this button sequence to run the diagnostic program and clear the error code:
Hi Temp - Heat Dry - Hi Temp - Heat Dry
Jan 01, 2015 | Dishwashers
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
FL code
The "FL" code indicates that the failed to lock the door, which would prevent the machine from running. You will need to replace the lock. Here is the part to order. Below is a video to show you how to replace it.
Dec 09, 2012 | Samsung WF337AA Front Load Washer
Fl error code
The "FL" code indicates that the unit failed to lock the door, which would prevent the machine from running. If this happens again, close the door tightly and restart the cycle. If the code reappears, your washer may require service. What is the model number?
Nov 02, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung WF337 Door will not opn FL
The "FL" code indicates that the washer failed to lock the door, which would prevent the machine from running. If this happens again, close the door tightly and restart the cycle.
Oct 22, 2012 | Samsung B1245 Front Load Washer
Received code P1400 engine light on what would cause this code?
GMC Truck Envoy - 2WD ' Envoy, Rainier, TrailBlazer, Ascender (VIN S/T) Service Manual ' Document ID: 1655997
DTC P1400
Diagnostic Instructions
• Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
• Review Strategy Based Diagnosis for an overview of the diagnostic approach.
• Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptor:
DTC P1400: Cold Start Emission Reduction Control System
Circuit/System Description
The catalytic converter must be warmed to efficiently reduce the emissions. The cold start strategy is to reduce the amount of time it takes to warm the catalytic converter. During a cold start, the engine idle speed is elevated and spark timing is retarded to allow the catalyst to warm quickly. This diagnostic monitors the following to build an exhaust energy model:
• Engine speed
• Spark advance
• Throttle position
• Engine airflow
• Engine coolant temperature
• Engine runtime
• Park/neutral position
• Vehicle speed
The actual model is then compared to the expected exhaust energy model.
Conditions for Running the DTC
• A cold start has been detected.
• The vehicle speed is less than 2 km/h.
• The engine is at idle with no input from the accelerator pedal.
• The airflow per cylinder is greater than 80 mg/cylinder.
• DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0120, P0121, P0122, P0123, P0220, P0222, P0223, P0201, P0202, P0203, P0204, P0205, P0206, P0300, P0335, P0336, P0351, P0352, P0353, P0354, P0355, P0356, P0502, P0506, P0507, P0601, P0602, P0603, P0604, P0606, P0607, P062F, P0641, P0651, P1101, P1516, P1682, P2101, P2119, P2120, P2122, P2123, P2125, P2127, P2128, P2135, P2138, P2176, P2610 are not set.
• This DTC runs for 15 seconds within the first 70 seconds of start up. This diagnostic runs once per trip when a cold start has been determined.
Conditions for Setting the DTC
The actual exhaust energy model does not match the expected exhaust energy model.
Action Taken When the DTC Sets
• The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Any loading of the engine that lowers engine RPM, such as with partial application of the clutch, during the first 70 seconds of engine run time may set this DTC.
Circuit/System Verification
Allow the engine to cool. Monitor the Cold Startup parameter. This should indicate Yes. Start and idle the engine for at least 2 minutes. DTC P1400 should run and pass.
Circuit/System Testing
• Inspect the air intake system for the following:
- If any other DTCs are set, diagnose them first. Refer to Diagnostic Trouble Code (DTC) List - Vehicle.
- Modified, damaged, or restricted
- Dirty or deteriorating air filter element
- Crankcase ventilation system for correct operation--Refer to Crankcase Ventilation System Inspection/Description.
- Water intrusion
- Vacuum leak and other un-metered air downstream of the mass air flow (MAF) sensor
- Intake manifold leak
• Inspect the exhaust system for the following:
- Water intrusion
- Exhaust leak
- Damaged, restricted, modified or enhanced exhaust system--Refer to Symptoms - Engine Exhaust .
Hope helps; keep us updated
Jun 30, 2011 | 2006 Chevrolet Trailblazer Ext
Lite flashes FL 2 , and a little man(saying service me?) where do i find a diagnostic code reference? thank you.brad
look on small cover inside it gives the codes but turn off reset heater and try again it might have been shut of while running
Feb 17, 2011 | Jandy Laars Lite2 Lj 250,000 Btu Heater
The washer will flash the code FL what dose this mean??? thanks for the help model 21062
fl flashes if any overfill condition occurs.this condition occurs when excessive water in the tub causes the overfill switch to trip.the control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for fl to be displayed.with an overfill condition ,the beeper repeats a warning every 10 seconds with no time-out.the pump is cycled in drain mode for 30 seconds on 30 seconds off untill the overfill switch resets or power is discontinued to the unit.press stop/cancel to clear the display.
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
Error code FL
FL means the door Locking Mechanism has failed. It will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
