Question about Samsung RF263AERS (258 cu ft) Bottom Freezer French Door Refrigerator
My fridge smells like anti-freeze. Steps to correct or aleviate smell I have kids
2 Suggested Answers
  • 949 Answers
SOURCE: Hot plastic smell and the wall between freezer and fridge is very
This is most likely due to an overheating condenser. I have put together some instructions on how to check and repair this. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
Posted on May 11, 2010
No leak and 2003 nissan xterra smell like anti freeze check radiator,water pump.hoses.heater core.anti freeze level in radiator is perfect
If you can smell,then you have a leak,if the heater core has a pin hole,then the box that houses it will hold the antifreeze to wear you won't see any,have to take the box apart and see,check your hoses going thru the firewall to see if there leaking.
Jan 26, 2016 | 2003 Nissan Xterra
Anti freeze on top of valve cover
Bad news!!! Blown head gasket. Sorry
Apr 02, 2014 | 2000 Buick Park Avenue
WHEN HEATER TURNED ON AND ENGINE WARM I SMELL ANTI- FREEZE CAN NOT LOCATE LEAKS
Are you able to see if it is the heater core? Located in dash on passenger side. Can often see them from bottom of the dash if you stick your head down by the floor boards.
Jan 25, 2014 | 2003 Kia Sorento
Rotten egg smells
Check smog controls. Smell indicates sulfur. Usually smog muffler.
Dec 25, 2017 | 2001 Ford Focus
I've been getting an anti-freeze smell in the cabin. Today, the windshield began to fog slightly with a terrible anti-freeze odor. This afternoon, the engine was running much hotter than usual. I...
if you r getting smell in car and fog on windshield, with known history for common problem, you have a heater core leaking, You could try a stop leak from a parts supplier, but you need a heater core, and is a rather big job, as entire dash needs to be pulled back to axcess
try stop leak, if that doesn't fix, you didn't waste alot of time and money
good luck, and if you wanna tackle job, let me know i will send guided steps to help you along
Jay
Jun 06, 2011 | 1998 Ford Taurus
I see a misty smell like anti freeze coming through the vents in the car
Holy cow you can see smells?????
haha just messing. If you have the smell of anti freeze coming through the vents it means that the heater core needs to be replaced. The heater core cycles the hot engine coolant and uses that to warm the air to give you hot air. If you can smell it it is leaking into the vent system and needs to be replaced.
Apr 22, 2011 | Buick LeSabre Cars & Trucks
I changed the lower raditor hose. Standard remove and replace. No problem. Replaced water and 1 gallon of anti-freeze. Let system warm up and turned on heater. No problems. Test drove and no leaks. Next...
the sweet sickly smell is normal for new anti freeze.once you have run the car for a couple of miles the smell will dissipate.the white foamlike stuff is chalk/lime in the water,harmless.
Aug 21, 2010 | 1996 Jeep Cherokee Sport
Unpleasant smell inside
Here's what you do. I know it is going to sound funny but it always works. Wad up a bunch of news papers and place them in the frige along with a stick of dynamite (only kidding about the dynamite) along with a box of baking soda. The newspapers will remove the smell in a couple of days.
Hope this helps
Dave
Feb 02, 2010 | Refrigerators
Heater immediately fogs all windows and there is a sweet odor in the cab of 2003 Buick Rendezvous, defroster works fine, but will not clear the windows after heat is put on
Sounds like a possible heater core failure(hole in it) the smell indicates to me the coolant(anti-freeze) is leaking into the passenger compartment.
Check the carpet in front of the front passenger seat for moisture, this would confirm heater core leak.
Good luck !
Jan 28, 2010 | 2003 Buick Rendezvous
Anti-freeze smell
Hi it could be a leaking heater core matix, Do the foot wells get damp at any time too, Hope this helps
Dec 11, 2008 | 1997 Pontiac Grand Am
Samsung RF263AERS (258 cu ft) Bottom Freezer French Door Refrigerator Logo
645 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
