2000 Chevrolet Cavalier Logo
Posted on Oct 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sensor 1 bank 1 sensor 1 P030 code from check engine light
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
454
Points
I have an error P0430 on my '2005 Nissan Armada, how can I fix this without having to pay my mechanic approximately $1K for repairs on the catalytic converter?
PHIL HINES
Level 2:
  • Expert 266 Answers
  • Posted on Oct 14, 2010
PHIL HINES
Expert
Level 2:
Answers
266
Questions
Helped
74559
Points
867
IT WILL BE THE SENSOR THAT IS CLOSEST TO THE ENGINE IN THE EXHAUST MANIFOLD
2answers
P1133/oxegen sensor
MAKE SURE THE CONNECTIONS AT THE SENSOR ARE GOOD,ALSO CHECK FOR VACUUM LEAKS,HERE'S A LINK TO YOUR CODE,THE OLD SENSOR MAY BE GOOD,JUST A VACUUM LEAK, P1133 Chevrolet HO2S Insufficient Switching Bank 1 Sensor 1
What does code p1131 mean on a 2001 ford taurus
bank 1 sensor 1 lean code. Check vacuum lines first. Could be egr leak also. Most vacuum lines run on the back side of the engine on these. Most common fail is the PCV 90 degree elbow. On the passenger side.
1helpful
2answers
What does the codes p0442,p0136 &p0141 mean on my 2001 ford taurus it failed inspection for these codes
P0442 FORD - Evaporative Emission System Leak Detected Small Leak
Possible causes- Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
P0136 - O2 Sensor Circuit Malfunction Bank 1 Sensor 2
Possible causes- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Faulty Rear Heated Oxygen Sensor Bank 1
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
P0141 FORD - O2 Heater Circuit Bank 1 Sensor 2
Possible causes- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
2helpful
Trouble code P030
The code should be for a failed heater in the O2 sensor bank one. Bank one would be on the side with cylinder one.
There may be an O2 sensor in each exhaust pipe and the computer says the heater in one of them is not working.
I would clear the code and drive it again to make sure the problem exists.
1helpful
Engine light code p1133 on a 2005 chevy colorado
P1133 CHEVROLET - HO2S Insufficient Switching Bank 1 Sensor 1xicon.jpghttp://engine-codes.com/p1133_chevrolet.htmlForum CodePossible causes- Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 shorted to Engine Control Module (ECM) ground
- Vacuum leak
- Faulty Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 connector and wires
2answers
P0138 and p0158
These codes, po 138 bank 1 sensor 2 shorted to voltage and code po158 means bank 2 sensor two shorted to voltage. these are the two rear oxygen sensors in the exhaust system. there two up frt and two in the rear, check the wiring on the two rear sensors, make sure that the wiring is not cut or stuck between metal. if the wiring is good then replace both rear sensors, when you get them ask for the left and right after the cat sensors. or bk1 s2 and bk2s2. after replacing them reset the computer. go to an auto parts sotre or if you have a code reader you can do it. hope this helps good day.
Air sensor check engine light
Ok as a guess that you have a SUV and you have different air faults. if you are a DYI'er go to an auto parts store and get an error code tool. Harbor freight for $30-50. Hook it to the car and find out which sensor is it calling for. Note, you can reset the check engine light on most tools that are not the cheapest.
P1130
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135
Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1150
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155
8helpful
3answers
Check engine light is on...bank 1 sensor1 oxygen sensor
if u have one oxygen sensor then u need to take a deep look at the bottom of ur car it will be somewhere at the Exhaust pipe if u have a catalytic converter then u will have two oxygen sensors one before the catalytic converter & the other will be after the catalytic converter. Note: the catalytic converter is located at after a little bit of beginning in Exhaust pipe.
I have problem with code 1126 (toyota 4 runner 2001
Manufacturer Specific Codes
P1100
BARO Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1120 Accelerator Pedal Position Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1126 Magnetic Clutch Circuit
P1127 ETCS Actuator Power Source Circuit
P1128 Throttle Control Motor Lock
P1129 Electric Throttle Control System
P1130 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1133 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1150 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit
P1300 Igniter Circuit Malfunction - No. 1
P1305 Igniter Circuit Malfunction - No. 2
P1335 No Crankshaft Position Sensor Signal - Engine Running
P1349 VVT System
P1400 Sub-Throttle Position Sensor
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1411 EGR Valve Position Sensor Circuit Range/Performance - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1500 Starter Signal Circuit
P1510 Boost Pressure Control Circuit
P1511 Boost Pressure Low
P1512 Boost Pressure High
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit
P1600 ECM BATT Malfunction
P1605 Knock Control CPU
P1630 Traction Control System
P1633 ECM
P1652 Idle Air Control Valve Control Circuit
P1656 OCV Circuit
P1658 Wastegate Valve Control Circuit
P1661 EGR Circuit
P1662 EGR Bypass Valve Control Circuit
P1700 Vehicle Speed Sensor '2' Circuit Fault
P1705 Direct Clutch Speed Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
Back To Top Of Toyota Check Engine Light Codes Page
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
