Question about Dryers
I have replaced the ignitor but still do not get fire.
    Problem Solver:
  • 87 Answers
Turn the gas on
Posted on Oct 14, 2010
The gas valve will not fire, the ignitor glows but no fire from gas valve
replace your ignitor even if it is glow there is current that need to pass in the ignitor wire and if it is not getting to that current it will not kick on the gas valve , even if it is glowing.
if it is more then 4 years it is that :)
Mar 26, 2011 | Dryers
Neptune gas dryer 9700 - drum turns fine, ventilation clear, but..... intermittent heat. Ignitor glows orange, then fires gas for about 10 seconds before fire cuts out - then repeats same process every 90...
ignitor that what i would replace you can test it with an amp probe your paper work should tell you how many it draws to open gas valve
Sep 28, 2010 | Dryers
I can see my ignitor light up but it does not fire. About every third load it will fire and it dries a load just fine. But then it doesnt fire the next time.
@Mike,
I've been where you are and it can be frustrating! What you described, for lack of a better phrase, is an 'ignitor dying a slow death.' Within each heating unit (aka. ignitor) there is a tiny thermostat that tells the device WHEN to fire and how often. Your trouble can be fixed by replacing the part. If you supply your machine make and model number we can help point you to a replacement part which you can get online.
Thanks, Chris I.
Sep 08, 2010 | Dryers
Running but not firing & heating
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gdryertroublevideo.html that will walk you thru this.
Jun 03, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
BOTTOM IGNITOR BROKEN,REPLACED STILL WONT FIRE
you need a volt meter to check this but if you can find you safty valve you can see if power is flowing through it by disconecting the ignitor and measuring the wire that comes to the ignitor and the other one that goes to the valve. if you have power you need to replace your saftey valve.you may allso ohm check the valve.if its open its bad
Mar 06, 2010 | Kenmore Ovens
Oven won't turn on but burners still will, the other day there was a small fire inside of the oven. The oven has not worked since that fire occurred, removed the sparker couldn't get fire started with a...
if you removed the Ignitor the oven will not light it has a safety valve that operates at this same time the ignitor is trying to get hot once it reaches a certain amount of power it will open the valve for the gas.
you may need to replace your ignitor,and or your electronic control board.
Feb 23, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Kenmore oven 362.75275690 won't fire...has new ignitor
if you get 120 volts to the ignitor, then the ignitor will glow ,if not you have a bad ignitor. the valve should have continuity through the the 2 connections.. its poosible to have 110v to ground at ignitor, the only way you get 110v you need to check power across the 2 wires to the ignitor( not to ground), and this will not happen with a bad safety vavle
Nov 23, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Lighting pilot of GE gas stove
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
Nov 27, 2007 | GE JGRP17 Gas Single Oven
Dryers Logo
Top Dryers Experts
