We installed AVG 8.0 on the server of our small office network on Saturday 31/05/08. However we now have "Big Problems" trying to access our S6 system on E:\ drive. (Solution6 accounting and taxation programmes.) When we go through "My Computer" to our Network Drives, we see the message "S6 System on Ser.... Disconnected Network Drive.An error occurred while re-connecting E: to \\Server\S6SYSTEM Microsoft Windows Network: The network path was not found. This connection has not been restored. Please advise a.s.a.p. as we are unable to process any data until the problem is solved.
    Brigadier General:
  • 6,966 Answers
Installing an anti-virus would be problematic on a server due to the many clients that would be constantly accessing files. Often, the server would also be lagging in responding since most of its time would be attending to requests and verification and anti-virus check of the accessing program from the client(s). Having said that, perhaps it would be to your advantage to install standard AVG on all of the clients and a AVG Anti-Virus Network Edition on the server.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 02, 2008
    Genius:
  • 3,422 Answers
Did you try uninstalling the AVG?Next you can also try a system restore but make sure you take a backup of all your important data.Bcuz once you do a system restore then you'll loose all your data as it will be restored to an earlier time.
Goodluck..
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Email problems: error code 0x800CCC0F,
When you use Microsoft Outlook Express to send and receive mail to a Post Office Protocol 3 (POP3) or Internet Message Access Protocol (IMAP) server running Exchange 2000 Server or Exchange Server 2003, you may receive the following error message. Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity.
Sep 29, 2011 | Microsoft Internet Explorer 7
Windows vista is not detecting lacie network space 2 i am trying to install a lacie network space 2 (1T) on a home network. i use windows vista icw avg free virus software. i installed the latest...
In your office network, for sure, you have a DHCP server who gave the IP addresses to all devices for that network and this seems to be the reason for why you could see your NAS. On home, you also need a DHCP server. You don't say anything about you home network. The best idea is to just make a temporary network with 2 devices: your computer and your NAS by connecting the NAS directly to your computer's network adapter, set the IPV4 IP for that adapter to the same class addresses as your NAS was set by default (usually NAS had "192.168.x.y" where "x" could be 0, 1 or 2 "y" could be any value between 1 and 254, but mostly, 1) and try to access it via http to manage him (need a user name and a password). For NAS default address and username and password, consult NAS user manual. Access it with from your preferred browser using: \\192.168.x.y
Once you gain the control, cut off his DHCP service and tell him to accept the IP address from the network defined DHCP. (btw: one normal DHCP server is allowed on one network! Cascaded DHCP also is allowed, but it's a little bit complicated)
Jun 25, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
"Chat is only available on newer browsers " Then
hello,
if all social network is block in you office try downloading and installing this to you computer it might work "http://hotspotshield.com/" it work for us maybe it will work for you...
thank you for using Fixya
Feb 26, 2011 | Facebook Social Network
Since I installed AVG I can not pull up Facebook. I get this message: A 50x server error was received attempting to serve your request, indicating that either the server is currently unable to handle the...
First of all, AVG isn't the best anti virus software, it's free but there's even better for free out there. Delete AVG and go download Avast Free Edition, it's better than AVG and is also free. I also bet that AVG isn't what's really causing your problems, try switching whatever browser you are using to Firefox but before you do that try deleting your cookies and clearing your cache.
Mar 24, 2010 | RTO Avg Anti-Virus & Anti-Spyware 8 for...
Unable to install AVG 8 free
Strippy had asked you a right question. You may be trying to install AVG when you have already one antivirus program running. OR you had once installed AVG sometimes in the past, but uninstallation was not properly done. Hence it is showing registry key error.
1. If you are running any anitvirus prog now, first uninstall it. Then restart the machine.
2. Now you try install AVG. it should install. if not, try the following
Go to system restore and create restore point for safety.
go to run and type regedit and then enter
Press cntrl + F for finding earlier registry keys of AVG. Try to find out all old registry keys amd delete them all.
Restart the machine. Its DONE.
Jan 15, 2009 | Microsoft Windows XP Home Edition
Client Printing + Word/Excel access times
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
369
Aug 06, 2008 | Microsoft Small Business Server 2003...
Connecting printer to SBS (Small Business Server)
You can physically connect the printers to the server and share it from there or leave the printers connected to your computer and have the server connect to them via a Local Port which routes to your computer!! To do the Create the local ports you'll need to 1.) share the printers on your pc 2.) Go to the server and go to printers in control panel 3.)Click on Add a new printer then next 4.)Select Local Printer connected to this computer; De-select Automatically Detect Printer 5.)Select Create new port and select Local Port 6.)In the enter a port name, enter the full network path to the printer i.e. \\your-pc-name\printer-share-name click ok 7.) Select the drivers for that specific printer(if its not there click on have disk then browse to the drivers to install them) 8.) Continue through the installation until finish) 9.) Repeat steps for additional printers Keep in mind that your computer still needs to be on! You can check to see if your printer support a network card to make them fully network printer you can add them to the server this way and only the server would need to be on! Or you can also get a print server(Device that makes regular printers into network printers). Now when it comes to the scanning, i don't know of any way to share a scanner with just windows alone, but there are third party software that allows you to do that Check out http://www.remote-scan.com/ There are also printers that sorta do the scanners sharing by automatically scanning and putting files in a designated area on the network! Hope this was helpful regards, babb
May 02, 2007 | Canon LaserBase MF5650 All-In-One Printer
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
