Question about Kenmore Washing Machines
Our Kenmore top load washer does not want to pump out the water. Model # seems to be 110 925 73210, set no. CE 1320006. After filling and agitating it won't drain. There is no pump noise.
  • 5,911 Answers
The most common cause of the symptoms you describe is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If model number is correct, the part number for a replacement lid switch is 285671. The lid strike (actuator) is 350733. If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Oct 14, 2010
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Washing Machine does not agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
46 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
