Question about Ovens
F3 on frigidaire
Ok I hope i am asking in the the right spot.Please give me all the info you can on fixing this problem.
  • 725 Answers
In a chat would work better I do need the model number..
Posted on Jun 04, 2008
I have Frigidaire oven when I press bake it gives me F3 on the panel wont start baking, then I have heat up the surface by turning on . Then only it will work ???
For Frigidaire ovens, F3 means that there is an open somewhere in the oven temperature sensor system or the wiring between the sensor or the oven control.
Since this goes away when you heat up the surface, I suspect a wiring fault. There is probably one broken wire in the unit, The thermal expansion of the wire when the surface is heated makes the two ends of that wire make contact again.
This wiring needs to be checked and probably replaced. (If the wiring is good, then the sensor is at fault.) If the appliance is still under warranty, contact the manufacturer.
I hope this helps.
(the wiring harness has a number of wires between the sensor and the control; each one will need to be checked when the entire range is cool and the open connection is present.)
Apr 21, 2012 | Frigidaire Ovens
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
F3 diplay after changing temperature sensor I had
Sorry to read about your problem, I hope this helps you out.
you may have a defective sensor card, plus i would recheck the wire nuts... check for around 1000 to 11000 ohms resistance.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My fridgidaire oven shows a f3 error code
F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 06, 2010 | Frigidaire Ovens
We need to replace the ignitor on a fgf326asf, we
The stove Frigidaire Mod. FGF326ASF give an F3 error don't have manual instructions, could you tell me please what that means
May 07, 2010 | Frigidaire FGB24S5A Gas Single Oven
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not come on after replacing the probe. still gives an f3 code.
Hi
Thanks for using FixYa. F3 error code means the oven temperature sensor (above 3000 ohms) is open and you need to check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. If there is no wiring problem then you need to replace sensor. Please also check resistance of oven temperature sensor.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
F3 F3 F3
F3 code means "The oven temperature sensor is open". Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
If your not sure how to do this, I recommend calling a professional to get it fixed.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
