Please can you give the model number of your Danby refrigerator
Thank You
In this model you have 2 evaporator coil and 2 evaporator coil fan.One for each side(left and right side).Check whether the right hand side evaporator coil fan is working properly.Is it cool or it is warm inside the right side?
Thank you
Please check the solenoid valve.This is the valve which send the freon to the specific side.So please check whether this is faulty.
Thank you
Thank You.If you want to get parts you can go to the below website and can order it.
http://www.searspartsdirect.com/partsdir...
Yes the refrigerant fully leaks off when you disconnect the solenoid.
Thank You
The dual zone wine cooler style is ideal for keeping both reds and
white wine without having to restore them in two different wine coolers.
Single zone wine coolers have one temperature control and the
storage space is undivided so the whole cooler is at the same temperature.
Koldfront makes a great dual zone cooler. I found you one that holds 18 bottles with
space for 6 bottles of white wine and 12 bottles of red.
danby dwc2121bls
the fans both work but it is warm on right side
it seems that the mechanism for letting the compressor know to send refrigerant to the evaporator coils is faulty on the right side. Which part controls that? Is it the solenoid valve or the pcb control or pcb sensor?
Ok I will thanks
Thank you
so can I check the solenoids by switching the wires on them, and if it is the solenoid it doesnt sound like it is something I can fix myself since the refrigerant would leak out had I tried to remove the solenoid and replacing it, correct?
