Question about Whirlpool Duet GHW9150P Front Load Washer
Sensor lock broken
Yes but how do you replace it?
  • 487 Answers
Lid lock broken. Can it be bypassed?
yes - jump the two wires going to the switch by the lock to bypass.
Mar 14, 2016 | Whirlpool WTW4800BQ White 27" Washer Top...
Water fills then want do nothing just sits there
This could be the door switch that is loose or broken.
Feb 15, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Front loader door lock not working
There is a peg that tells the switch to close. If you have parts that are broken, replace them.
Dec 09, 2013 | Frigidaire Washing Machines
LG 1056QD front load washer door will not open. It's locked. I have tried forcing it open but didnt work. Any suggestions please?
sensor is not fully trip to open position check the sensor there must be a broken plastic thats prevent the sensor in open position the sensor is located inside the machine behind the door
Oct 26, 2013 | LG F1402FDS6 Front Load Washer
My LG washer keeps displaying DE and makes door clicking noise and if it unlocking the door and will not start a cycle. We have bought a new door sensor, and control panel. What else can it be?
Hi dear.According to your explanation,MAIN PWB ASSEMBLY is faulty.Not the door lock or control panel.However you can try this & see if it's works.I hope that helps.Thanks. Does the spring of Latch Hook actuate?If No:Replace door assembly
Is there clicking sound once or twice when the
START/PAUSE button is pressed to start the cycle? If No:Check the DOOR SWITCH
ASSEMBLY Connector and
MAIN PWB ASSEMBLY
(Red 4 pin and white 4 pin
connector (1)).
Is DOOR SWITCH ASSEMBLY broken?If Yes:Replace the DOOR
SWITCH ASSEMBLY
Aug 21, 2010 | LG WM-2277HW Front Load Washer
F28 continues to show on display.
Comunication error between motor control unit and Central control unit. Broken wire in the harness.
F01 power glitch: disconnect power for 2 mins verify correct CCU operation
F11 Motor control unit internal failure MCU board failure or broken wire.
F20 No water detected entering machine, pressure switch hose clogged
F21 Long drain Possible cause: Clogged filter, clogged/failed pump
F22 Door lock error Failed lock. corrosion,or broken wires.
F23 Heater Failure Bad heater
F24 Water temp sensor error Failed sensor or heater
F25 Motor Tach error Bad MCU (motor control unit) or broken wire
F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
F27 Overflow condition Clogged drain, pump, kinked hose.
F28 Com error between MCU and CCU (central control unit) Broken wire
F29 Door unlock error bad switch,broken wire,corrosion
F30 Dispenser system error Bad or jammed motor, broken wire
F31 MCU failure due to motor overheating.
F33 Pump drive system error, broken wire, corrosion
rL (prewash)Clothes detect. Remove clothes and retry.
5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
For diagnostics and further info refer to this handy dandy:
DUET SERVICE MANUAL My tip:
http://www.fixya.com/support/r4232744-duet_sport_washer_error_codes
Mar 21, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
The washer does not run through the wash cycle. The door locks but nothing further happens. There is an "LE" error message but I do not have a manual that explains what that means. Please help.
The LE error message means locked motor error and it is almost always accounted for an out-of-order Hall Effect Sensor. Other causes includes defective Main Board and broken wiring harness.
To check the Hall Effect Sensor:
  1. Unplug the machine.
  2. Remove the top plate assembly by unscrewing the two screws on the back of the top plate.
  3. Look for the Main Board assembly on the rear left side of the machine.
  4. Remove the power connector and sensor switch assembly.
  5. Remove the Main Board assembly protection cover by releasing the latches along its sides.
  6. Look for the 4-pin white connector with white, gray , red, and blue wires. It is the wiring harness going to the Hall Effect Sensor. Disconnect it from the board.
  7. Using a multimeter, check the resistance between the white and blue wires and between the white and red wires. Resistance should read about 10k ohms.
  8. If either resistance reads open, check for a broken wiring harness and repair or replace as necessary. Otherwise, the Hall Effect Sensor is defective and must be replaced.
  9. If the tests above show that the Hall Effect Sensor seemed to be good, you have to check if the Main Board delivers 10 to 15 Vdc supply to it.
  10. Reconnect the machine to the power outlet.
  11. Press POWER but DO NOT PRESS START.
  12. Set the multimeter to DC volt and measure the voltage between white and gray wire terminals on the Main Board. Voltage should be 10 to 15 Vdc. Otherwise, the Main Board is defective and must be replaced.
  13. Connect the red test lead to the red wire and the black test lead to the gray wire.
  14. Turn the motor rotor slowly by hand.
  15. You should measure a pulsating 10 Vdc if the Hall Effect Sensor is okay.
  16. Repeat the step with the red test lead connected to the blue wire.
  17. If you measure a 10 Vdc but not pulsating, the Hall Effect Sensor is defective and must be replaced.
Feel free to inform me if the Hall Effect Sensor or the Main Board needs to be replaced and if you want to replace it yourself.
Dec 31, 2009 | LG WM-2277HW Front Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
11F ERROR
Door lock sensor broken/need to replace.
Aug 27, 2007 | Kenmore 43142 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
