Question about GE GSH25JFT
GE SmartWater MWF Refrigerator Filter is making noise when dispensing water
The filter body for the unit is poorly designed and can only stand maybe 8 filter changes before it starts failing to open fully with the new cartridge. As far as I can tell the only solution is to replace the filter body.
Posted on Feb 02, 2013
SOURCE: Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Posted on Apr 29, 2008
  • 150 Answers
SOURCE: GE SmartWater Filter - Model MWF
make sure filter is installed correctly (not to doubt you but it can happen) make sure there isn't some foriegn object or packing materialetc in the filter end. You could have a bad filter. also make sure the unit is purged well
Posted on May 15, 2008
  • 351 Answers
SOURCE: do add water ge smart water mwf cartridge
i dont believe so water will fill it, it should reconize the filter and fill it... i believe i may be wrong but that is how it usually is.... did it come with instructions?
Posted on Apr 19, 2009
SOURCE: Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
Posted on Jul 22, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have a GE Profile
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Posted on Nov 03, 2010
Ice won't come out
if it's making ice, but the ice won't come out, it is likely going to be the dispenser motor (found behind the ice bucket).
the other possibility is the lever where you put the cup could not be hitting the switch, but most likely it is the dispenser motor.
May 21, 2012 | GE Mwf Ge Refrigerator Smart Water Filter...
After installing a new mwf filter no water comes out of the dispenser. It worked before changing the filter. With the filter bypass plug installed - still no water. I held the dispenser for more than 3...
the inlet valve has jammed shut & needs to be replaced it's just coincedence that it happened when you changed the filter unless the taps turned off it has to be a faulty inlet valve.
Feb 18, 2011 | GE 3 Ge Mwf Smartwater Water Filter Fits...
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Do add water ge smart water mwf cartridge
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
May 15, 2008 | Refrigerators
Apr 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSH25JFT Logo
943 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
