Thermostat
Removal & Installation
2.2L Engine
To Remove:
To Install:
2.4L Engine
To Remove:
Thermostat assembly 2.4L
To Install:
3.4L Engine
To Remove:
To Install:
SOURCE: where is the electronic flasher located in an
turn the 4 ways on and listen for the location,It can be in one of three places,The fuse box,up under,and around the steering column.or over behind the glove box.You moght have to drop the glove box down to see it.
SOURCE: locate thermostat 2002 alero
THERE A CROSS OVER EXHAUST PIPE TO THE FRONT EXHUAST MAG ON BACK OF THE ENGINE OVER THE TRANS RIGHT IN BACK OF THAT PIPE CENTER OF THE BACK OF THE ENGINE.
SOURCE: LOCATE THERMOSTAT ON 2002 ALERO
Follow the upper radiator hose to the engine. It should be located in a housing near where the hose connects to the engine.
Drain the antifreeze, follow top hose to bottom of engine. Bolts
probaly come out from top, but will be under manifold, ouch, pain in
but.
hope it works
