Question about KitchenAid Refrigerators
Our ice maker stopped working after our town had a water shortage and shut off supply for a period of time.
    President:
  • 1,891 Answers
Ck the wate valve and the screens in the valve they may have pluged off . mm
Posted on Oct 14, 2010
  • KitchenAid Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
When there is a long term water outtage all kinds of things can be introduced into your water system. Most likely there is debris in your water supply line or water valve assy on your refrigerator.
1. Turn off the water supply to your refigerator.
2. Remove the water supply line
3. Turn on the water and purge the water line. ( If there is not water coming through the line at this point the water shut off valve at the supply connection is probably clogged. ) Then reconnect the line and turn on the water.
4. After purging the supply line unplug the refrigerator
a. Make a test cord for the water valve solenoid by using an old extension cord and cutting off the end and installing female termials available at any applaince parts source or some hardware supply sources.
b. Remove the fiberboard rear cover of the unit and gain access to the water valve
c. Disconnect the 2 terminals of the ice maker water valve solenoid and connect your test cord.
d. Remove the plastic line that goes to the icemaker at the top connection by pulling down and place in a bucket.
e. Plug the test cord into the wall outlet. Water should flow into the bucket.
f. Unplug the water valve solenoid test cord. Water MUST stop.
If you do not get water flow at this point your water valve is clogged. You can either try to reverse flow with water and power to unclog it or... use LP air at a distance pointing into the top plastic line with the test cord connected to the wall outlet. If it does not clear then your only option is to replace the water valve.
g. Remove the test cord and reconnect unit wires to the water valve solenoid.
Here is a link on how to cycle the ice maker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Just note that there is only 7.5 seconds that water is supplied when the sweep fingers are near vertical.
Thanks for choosing FixYa.
Kelly
Samsung rs257 ice maker not working. We already reset ice maker and checked water line to ice maker. We also used dryer to defrost bearing on ice maker. Still not working.
Hi!
The manual provides a number of reasons why the ice maker doesn't work:
Ice is not dispensed
Did you stop the ice making function?
Is there any ice in the ice storage unit?
Is the water line connected and the shut-off valve
open?
Is the freezer temperature too warm?
(Set the temperature lower)
Did you wait for 12 hours after installation of the
water supply line before making ice?
I'm adding a link to the manual:
http://manualsbrain.com/en/manuals/948215/?page=29
Jul 21, 2017 | Samsung Refrigerators
Ice billed up in and around ice dispencer even when ice maker is off.
You don't mention a brand or model. All ice makers and chilled water dispensers must have a household water supply. This is controlled by water valves (much like a washing machine) that turns the water flow on and off as needed. If you've cleaned out the ice maker compartment, cleared away all ice build up and the icing problem recurs (usually over a period of days) then the water valve is leaking which lets water dribble into the ice maker compartment forming the ice. You can prove this by shutting off the water supply to the refrigerator (or even disconnecting it.) A new water valve should solve the problem.
Nov 01, 2016 | Refrigerators
Jenn-Air JFC2089HES ice maker
Try letting it thaw out and re start it.
Jun 19, 2014 | Jenn-Air Refrigerators
THE WATER NO STOP IN ICEMAKER MOD GSS25SGM GE
Improve the FixYa experience for everyone by voting.
Suggested approach to fixing your problem:
Your ice maker is designed to fill with water for 6 to 8 seconds. Depending on your city water pressure, anything longer than eight seconds will overfill the ice tray and either over flow the ice maker or create cubes that have difficulty ejecting.
There are two basic issues that commonly cause an overfill condition.
  • The first is an ice maker that is sending power to the water inlet valve for a period longer than eight seconds.
  • The next problem which is the subject of this answer is a water inlet valve that is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to imperfections in the valve, it is closing in a delayed fashion.
How to Diagnosis:
The easiest way to determine if your water inlet valve is the culprit, is to install a meter volt meter across the leads of the water inlet valve.
  1. Set the voltage range for 110v.
  2. Manually cycle the ice maker and watch the meter.
  3. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker.
  4. Note the difference in time between when the voltage is cut from the valve and when the water quits filling the ice maker.
  5. If the water shuts off immediately when the voltage is removed, the valve is likely operating correctly.
  6. If this is the case, it is likely that the voltage will be applied to the valve for a period of time greater than eight seconds.
  7. This generally indicates an ice maker control problem.
However, if the voltage is removed from the valve and it continues to fill, the valve is likely at fault. This indicates that due to particle build-up or mechanical failure the valve has lost its ability to shut immediately. In that case, simply replace the valve and it should fix your problem.
May 13, 2012 | GE Refrigerators
Icemaker started shooting water in a contoiuous stream and ran all over the kitchen what happened?
Good day,
The process is as the ice maker runs thru a harvest cycle, during the end of the cycle the ice maker sends a signal to the water valve on the bottom rear of the machine to open for approx. 7 seconds to refill the well of the ice maker.
If you unplug the machine while this is happening, and it stops, then it is an electrical problem inside the ice maker.
If you cannot make this work, and you have to shut the water off to the machine then it is a faulty water valve on the bottom back of the machine.
Replace whichever item is causing the issue, ice maker or valve assembly.
Good reason to shut off the ice maker and water at the house meter when gone from the house for extended periods of time, such as a vacation, weekend trip ect.
I had a call where this same situation occurred in an upscale home with the parties gone resulting in approx. $30,000.00 damage to the home.
May 20, 2010 | Refrigerators
Icemaker not making ice. Water supply is good, turned on icemaker; solenoid resistance is 338 Ohms. Can't blow through plastic water supply tube at back of refrigerator. Supply valve screen had some...
Good day,
First, measuring the coil Resistance doesn't work. A valve can measure fine, but refuse to open.
First, shut the water off to the house at the meter. remove the line from the valve, put the line into a bucket, and have someone turn the water valve on full for a 15 second or so count. The water must come out and strongly.
Unlike an automatic washer, the ice maker is a time fill. 7 seconds period.
Second, it is not unusual for the file tube that runs from the back of the machine and into the back of the ice maker to ice up.
Common problem, and is caused by the water valve on the back rear of the machine to leak slowly on the off cycle. Water valve must be replaced with new.
Remove the ice maker to inspect that fill tube. If iced, thaw out.
Beware of hair dryers. Too much heat can cause serious problems if plastic and/or vinyl parts get melted.
I don't recommend heat. A pain, but unplug the machine for 12 hours with the freezer door open.
Nov 29, 2009 | Refrigerators
Ice maker not working
The activity with the water supply could have loosened some sediment in the line stopping up the little wire screen filter going into the water inlet valve. I would disconnect it and inspect the screen and flush the water line out before re connecting. Assuming you have water at the water dispenser Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 30, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Ice maker stopped working on Whirlpool side-by-side S25BRSS31-A/G
some whirlpool fridges have a faulty circuit board (which is caused by overheating due to a design problem) which they only tell you about if you sign up for a 1 year service contract (if you are out of the warranty period).
Aug 08, 2009 | Whirlpool Refrigerators
Ice maker for Kenmore model 532343 not working
Does your water have minerals?
Faulty Water Valve
Your ice maker is designed to fill with water for 6 to 8 seconds. Check to see that the ice maker is not sending power to the water inlet valve for a period longer than what you unit is designed for. Does your water have minerals?
Also check to see if the water inlet valve is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to wear and tear in the valve, it is closing too slow.
Check the timing on the value. Put a volt meter across the leads of the water inlet valve. Set the voltage range to cover the 120v voltage. Cycle the ice maker and watch the meter. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker. Time the difference between when the voltage is cut from the valve and when the water quits filling the ice maker.
If the water shuts off immediately when the voltage is removed, the valve is probably good. Since it was off 10 days the particle build-up on the valve may be the problem since it could solidify. You could try working the valve back and forth or replace it.
If the valve closed quickly then the problem is the valve was opened too long.
If that is the case then you have an ice maker control problem. In that case see if the timing can be adjusted.
Mar 24, 2009 | Kenmore Refrigerators
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
137 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
