Question about Kitchen Ranges
Where are the fuses located for the burners on a moffat stove. model number mcbs524
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Posted on Jul 13, 2010
SOURCE: I have a older model
I have a Moffat Westwood range and the oven doesn,t work. the fuses are good. Is this a problem with the timer settings?
Posted on Jul 18, 2011
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
Burner says hot.. wont go off, moffat stove
Hello;
My name is Peter. I am a retired field service appliance technician.
I assume you have an electric oven.
You have a defective individual burner control.
1.) Pull your oven out so you can get behind it.
2.) Unplug your oven.
3.) Remove the upper back metal cover.
4.) At the top in the center is your main oven control board. On the left are two burner controls and on the right are two burner controls.
5.) Inspect the burner controls for burn marks or melted wires.
6.) Finding the bad control unit, pull the control nob off the front.
7.) Unscrew the burner control in the front.
8.) Remove the connectors on the burner control.
9.) With the burner control in hand. re-attach the upper metal back panel on your stove.
10.) Pug in the stove and push back in place.
11.) On the burner control that you just removed note the part number. Search on the internet for best price.
12.) Continue to use your oven without the burner control.
13.) Install the new burner control when received. Remember to un-plug.
May 15, 2015 | Kitchen Ranges
A burner on my ceramic stove top doesn't work
Without the brand and model number, it is difficult to answer your question. There should be a reference number somewhere in your stove top. That would be your starting point, and from there, seek the needed info using the model number and make. Try a new ceramic burner assembly at that location....it's plug and play.
Jan 08, 2015 | Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Where are my electric stove's fuses located (if that is indeed the problem)?
The electronics were probably destroyed by the lightning strike.
Heating elements can withstand voltage surges but not the more sensitive electronics.
The oven is controlled by the timer but none of the top burners are. Using the Brand name and Model number you should be able to buy parts. The controls may all on a single board.
Aug 22, 2014 | Kitchen Ranges
I am looking for a fuse in my antique stove 1948 moffat
I have a Moffat of about this vintage. Are you saying you can't find where the fuses are? Mine are underneath the left-hand drawer - the drawer under the warming oven. I just pull the drawer out and I can see them.
Sep 12, 2010 | Ovens
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
1952 Moffat Bake Stove
I have a working 1952 moffat stove with warming oven if interested
Oct 27, 2009 | Kitchen Ranges
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
