Question about Plantronics CS70 Wireless Headset
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Posted on Nov 01, 2011
Hi, my Plantronics CS70 earpiece only stays connected for about 2 secs and then shuts off. The battery is fully charged and the earpiece is properly synced with the base. Any ideas? Thanks, Jeff
It sounds like it may have an incorrect setting for the phone. This is the 1-4 in the side of your base. The number that configures to your phone should be listed at the 3:00 o'clock position. Most phones are used on 1. Here is a link to the User's Guide, that may help. The only other thing is it sounds like the battery is not really charging, which means that it is a non-replaceable battery. In that case, you would have to buy a new headset.
Sep 08, 2011 | Plantronics CS70 Wireless Headset
The headset does not come on
CS70 headset does not come on:
If the CS70 base has lights, to show that it is getting electrical power, you may need to re-pair the headset to the base unit (the headset will usually just beep when you press the button). Here is the link for subscription or how to re-pair the headset and base.
http://www.headsetsdirect.com/plantronics-cs70n-subscription-pairing-instructions
If the headset doesn't beep or anything when the button is pressed, and the base has lights, it could be that the internal battery has worn out and the headset needs to be replaced. The CS70 is an older model that has been discontinued for a few years, however you can get the CS70N replacement headset which will work on your base.
http://www.headsetsdirect.com/72910-01-cs70n-headset.html
Aug 07, 2011 | Plantronics CS70 Wireless Headset
I used the mute feature on my new headset and after 20 min it discontinued the call. Now the headset will not connect to the lifter. I tried resetting and it still will not connect
Sometimes just unplugging the power adapter on the base of the CS70N and letting the power drain out will help. If you can leave the unit unplugged over night that's even better. Plug it back in the next day and let your headset charge up for a few hours. Then try repairing headset to base. I have included Headsets Directs link for pairing headset to base below.
Plantronics CS70 Pairing Instructions
Jul 12, 2011 | Plantronics CS70 Wireless Headset
The Headset Lifter won't pick up the calls. Nothing happens when I push the ear button to lift it up. I thought maybe it wasn't fully charged when I tried it yesterday. At that point, I made...
If the CS70 headset has a charge and beeps when you press the call control button, you may just need to re-pair or re-subscribe the headset to the base unit. Here is a link for the pairing / subscription instructions:
If the headset is not charging, the internal battery may be worn out and the headset may need to be replaced (the battery is hard wired and is not replaceable). The replacement headset is model 72910-01. Below is a link where you can purchase the replacement headset.
Plantronics CS70 Replacement Headset
Jun 24, 2011 | Plantronics CS70 Wireless Headset
Need to pair to mobile phone is that possible if so how
The CS70 does not have Bluetooth, so it cannot be used to pair to a mobile phone.
Mar 01, 2011 | Plantronics CS70 Wireless Headset
How do I sync my replacement ear piece
Dec 08, 2010 | Plantronics CS70 Wireless Headset
I need to pair my plantronics (voyager) earpiece with my new phone. I don't have my instructions anymore. I cannot get it paired up with my phone. How do I do that if I don't have the numerical code for...
hello, . Press and hold the power button until the indicator LED flashes red/blue. The Voyager Pro headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again until you see the red/blue flash. try 0000 as the code good luck
regards
shaun
Oct 10, 2010 | Plantronics Radio Communications
We had to order a new headset (ear piece) to our CS70 system. Do we need to program it? It is not picking up the handset.
To pair another headset to the same base, you must first enable the multi-shift
pairing feature. Long press (5 sec.) the speaking volume minor adjust up button on
back of base until the power indicator light flashes.
2. Place a charged headset in charging cradle and red indicator light on base will flash
for 2 seconds if the multi-shift pairing feature is enabled. Within 10 seconds of
doing so, press either the "+" or "-" listening volume button for 3 seconds until the
headset talk indicator lights to indicate pairing mode, and goes out after successful
pairing. Repeat steps
Jul 11, 2010 | Plantronics CS70 Wireless Headset
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
Dec 21, 2009 | Plantronics Explorer 330 Headset
Can the hfblu-1k be reset?
you do not have to reset it to pair it with another device. you simply have to put the earpiece into pairing mode again as you did with the first phone and follow the same steps you used initially to pair it to the device that broke.
May 04, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Plantronics CS70 Wireless Headset Logo
94 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
