Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer GLEQ332AS1 at one point in revoution of tub a loud klunk like a gym shoe and a scrape. I think it's a bearing what do you think. What is the best way to access it.
3 Suggested Answers
SOURCE: Clothes Dryer in need of repair
if you look inside the drum can you see 3 screws? if you are mssing 2 then it will klunk.
Posted on Nov 01, 2008
hunter19_46m
  • 7482 Answers
SOURCE: Loud klunck and scrape sound in one place when
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
#1...
The scraping noise is coming from the drum rolling on the metal frame, your front seal is probably worn out.
#2...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Oct 14, 2010
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Ewf1087- loose rear flywheel-belt wont stay on.
Check your wash tub bearings first. From the front, grab the stainless wash tub, and see if you can lift it up and down. Imagine it was a wheel on your car - if you could wobble the wheel about and it wasn't solid, the wheel bearing would be gone - same with your washer.
If machine is getting near 6 years old - probably best to replace it. Bearing repairs are never easy or cheap.You won't have a machine that is as good as new after - you will have a worn out machine with a few new bits in. A loose flywheel means the shaft / fixing point is worn - the wheel will be too. They are usually fixed with a star point TORX bolt, that is locktighted on in the factory. It should never come loose - unless you have major problems.
Oct 31, 2017 | Electrolux Washing Machines
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The dryer is making a loud noise. Think its the
the belt that spins the dryers drum around has a belt tensioner located at the botton base of the body. If the roller bearing goes bad the sound you hear is caused by that. Replace the belt as well when replacing the roller or the whole tensioner if needed
Feb 06, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Lots of klunking noise when drum tuns, otherwise works great
klunking noise
ok this could be a sticky idler pully,
it locks up for a second then skips
or it could be one of your back rollers
has a bad bearing
you can check this by holding the door switch closed
if its the idler, you will see the tub jump when the belt catches up
if its the roller, you will hear it in the back
Oct 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
A slipping sound then a continued loud thumping noise
This could very well be the guide rollers in back of the cabinet. They will do this if there is considerable wear. They probably need to be replaced.
Nov 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Aug 06, 2008 | Frigidaire FEQ332E Electric Dryer
Remove motor
what i will do first is change your rear bearing obviously it is worn out leaning downward putting unnecessary strain on motor..
if you notice it is motor too which is rarely the problem, take the drum out, disconnect wires to motor, remove clips holding motor.
Apr 02, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
46 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
