Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Can we use cast iron cookware (e.g., frying pan) without damaging the range grates?
    President:
  • 2,777 Answers
Yes you can definitely use iron cookware on this range without an issue. It is made for all types of cookware. Just make sure you do not drag the pan against the grates, but any cookware would hurt the grates if you did that.
You are definitely safe to use them.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Posted on Oct 14, 2010
  • Tim Grayson
    Tim Grayson Oct 15, 2010
    If possible please come back to the question and rate my answer. It would be much appreciated if you could rate me 4 thumbs up. I am in very desperate need of the rating! Let me know if you need more help.
    - Thanks -
    Tim
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
How do I clean my cast iron skillet?
for some people, a "Visual" is preferred, over a good lesson provided you like to read, btw - thank you Aiden,...
So, if that is you, a preferred Visual learner, then watch this...
May 01, 2013 | Home
How should I store my cast iron skillet?
You should store it without the lid. If you leave the lid on then it is more likelt to rust. Some people even put a paper towel inside to protect against moisture. I leave a paper towel in all my pans.
Jan 16, 2013 | Home
Which is best porcelain or cast iron grates? I am
Cast Iron by far, ceramic grates chip and are VERY difficult to clean!!!
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Can I use cast iron on a glasstop electric range?
yes it is true, the heat transfer will be to great and will crack or explode the glass. definately not recommended.
Nov 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cleaning the cast iron grates and griddle
Take the grates off and slide them on your dishwasher rack and run them thru a cycle... pull them out before dry if you want..
May 31, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Glass cooktop scratched
Unfortunately, these style cooktops are VERY fragile to scratching and cracking. The wrong kind of cookware can also mark them. Copper or aluminum pots and pans can discolor them. Do not use pyrex (glass) cookware on them either. Stainless is the best. NO CAST IRON either. Anyways, there's not much can be done without replacing the top itself.
Apr 09, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Can cast iron be used on GE glass top stoves?
Cast iron is not recommended due to the weight and its heat retention. Cast iron stays hot longer and, due to the weight, can damage the cooktop surface by scratching or cracking it. In your owner/operator manual there should be a section that defines what type of cookware that can be used. Aluminum and Copper heat rapidly, but can leave metal transfer marks. Stainless takes longer to heat and doesn't always heat evenly. Baked enamel, I believe, is the recommended cookware, because it is light weight, heats evenly and has a less risk of damaging the cooktop.
NOTE: References to any remarks about metal transfer marks made by cookware are DISCLAIMERS letting the consumer know that the POTENTIAL of marking the cooktop surface exists. This is NOT to imply that the cookware should not be used. There should be clear instructions that state how to remove the marks (if it occurs), what recommended cleaners are to be used and how to properly keep the cooktop surface clean. Spillage from milk or sugar substances can cause more damage than metal transfer marks.
Another item to note is the cookware bottom should be smooth and flat. If you sit a pan on the range surface and it does not sit evenly, you can potentially crack the cooktop surface due to uneven heating.
A warranty in most cases does not cover damage or breakage of the cooktop caused by the consumer using improper cookware or dropping something on it and breaking the surface.
Not trying to give you a lecture here, just trying to give you some advice just in case you weren't aware. I hope you find this information helpful.
Apr 09, 2008 | Kitchen Ranges
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
90 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
