Question about Danby DWC2121BLS Wine Cooler
Left side cooling but right side not cooling - Danby DWC2121BLS Wine Cooler
    Problem Solver:
  • 87 Answers
Might have a kinked line.
Posted on Oct 14, 2010
Why am I getting cool air conditioned air out of drivers side, and hot air out of passenger side (want cool ac on passenger side also).
There are 2possibles ,1. The heat / cool slide control is defective, it is not possible to repair. Most likely the servo motor that opens and closes the air vent that gives you heat or cool is stuck. Open your glove box and you will see 2 rubber tabs that hold the door at the open and down position. Push down on your glove box door until it swings all the way down (this wil be past normal open) up inside you will see a metal rod affixed to a arm that pivots via the servo left is full vent(cool) right is full heat. Push your hot/cold heat selector and see if it moves. It may not be moving its full extension. If your not sure push it right and you should get heat push it left and you should get cool check YouTube this is a common problem for this era of Buicks, good luck Bret
Mar 15, 2015 | 1998 Buick Park Avenue
Left side exaust is cool, right side hot, and more carbon on the right side , why?
The cool side would indicate a cylinder not firing or a misfire--no fire would equal no exhaust to make carbon.
Aug 21, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Geting erro of 59.00 in 4250 printer
hi
HP LaserJet 4250n Printer - (Q5401A)
replace the fan --- erro 59.00 is failed fan.
on right or left of printer
Fan RK2-0278-000CN In stock
Cooling fan - Located on left side of printer (FN101)
RoHS: Modified
93.60 0.00 93.60 RK2-0280-000CN In stock
Cooling fan - Located on right side of printer - Provides air to the print cartridge area (FN103)
RoHS: Modified
Aug 01, 2011 | HP LaserJet 4250n Printer
GSS201ETA BB Right Side is not cooling ( Freezer on left is fine, have removed all shelving and ice tray ) No cold air is flowing to the right side ! What do you suggest to troubleshoot ? Thanks in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | GE GSS20IEP Side by Side Refrigerator
Fusebox location
Relay Center Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Let me know if this helps. If not, let me know.
Circuit Protection The fuse panel is located below and to the left of the steering column.
Fuses are a one-time circuit protection. If a circuit is overloaded or shorts, the fuse will blow thus protecting the circuit. A fuse will continue to blow until the circuit is repaired.
Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal.
Aug 07, 2010 | 1991 Ford Tempo 4 Door
Fan stopped working causing engine to overheat.
Which one is working?... the one on the right or the left? The one on the right is for the Air Conditioning (primarily).. the one on the left (driver's side) is for cooling the engine (coolant). If the one on the driver's side isn't working, check to see if there is power (battery voltage) and ground to it (the ECU turns it on when the coolant temp is above 208 degrees). If you have power & ground at the cooling fan connector, then the cooling fan motor is bad.
Oct 18, 2009 | 2001 Hyundai Tiburon
Where is the fuse box panel for a 1993 ford tempo
Access the fuse panel from the left of the steering column Relay Center Cooling Fan Controller
Cooling Fan Relay
Fuel Pump Relay
Horn Relay
Oct 13, 2009 | 1993 Ford Tempo
FUSE BOX DETAILS
left to right...
1. empty
2. e flashers
3.horn, brake lights
4.clock, trunk light, inside light, radio
5. rad. cooling fan relay (AC only)
6. right side running lights
7. left side running lights
8. right high beam and indicator
9. left high beam and indicator
10. right low beam
11. left low beam
12. reverse,turn signal and inst panel
13. main and transfer fuel pumps, auxiliary air reg., ox sensor heater
14. license plate and glove box light
15. wipers
16. rear defogger
17. heater blower (no AC)
18. cig lighter
19. rad cooling fan (no AC)
20. Heater blower (AC)
21. rad cooling fan (AC only)
22. empty
23. Ox sensor, idle stabilizer,seat belt warning relay, (Digifant only, control unit, idle boost control, idle boost valve)
24. inst panel lights, heater control lights
25. reading lamps
26. empty
27. empty
28. empty
Hope this helps...;-)
Apr 17, 2009 | 1992 Volkswagen Fox
Danby DWC2121BLS Wine Cooler Logo
279 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
