Question about Stanton C314 Tabletop CD and Mp3 Player
Im looking for a new power supply for my C314 as mine was cooked... Do you have any idea where i can get one from??
  • 94 Answers
GO TO SITE CALLED ASK.COM.
Posted on Oct 25, 2010
When i turn the cd player on its reading like a cd is in it but it not
reverse the pin of mains supply and try ,and open close cd tray switch,clean cd tray with smooth brush
Sep 03, 2012 | Stanton C314 Tabletop CD and Mp3 Player
My C314 turns on but none of the bottons work.
Hi, I have the same problem if you decide to ask her to tell how?
Aug 06, 2012 | Stanton C314 Tabletop CD and Mp3 Player
Behringer DDm4000 purchased in 2009. Over 2 years happy usage, but now it's got some major issues! The power supply seems corrupted as after about 2 hours use it maxes out the signal (ouch) and all...
Behringer is stingy about schematics... however here is one for their DJX700 which MAY have a similar power supply to yours:
http://elektrotanya.com/behringer_djx700-professional_sch.pdf/download.html
Scroll down to "get manual" and click to download... IGNORE other download links.
On page 9 near the lower right corner is the simple power supply, minus the transformer but showing the rectifier diodes, filter caps, and the three terminal regulators. These regulators have a thermal shutdown feature so if they seem to run VERY hot they might cause your problem. Common things are failing electrolytic filter caps. Behringer also uses switching power supplies in some gear and I have schematics of examples of those as well... but peak in your unit and see what type supply you have.
Jul 28, 2011 | Behringer Ddm4000 5-channel Digital Midi...
Im using a behringer ucg102 guitar/usb interface, im getting a very bad hum/hiss.. i've tried 3 different guitars and multiple jacks. im not running any guitar effects yet, i've removed the...
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
Jul 23, 2011 | Behringer energyXT2.5 Plus Portable...
My power supply in my phonic helix mkII 24 board is blown, it was messed up in a power surge, I have tested the remaining connecting parts and everything else is fine. I contacted phonic and they dont...
Usually it's the electrolytic caps that go in those, they basically "cook" and dry out, a power spike just pushes them over the edge. I've also had this problem with mine & 2 12 volt switchers for my HD and for the satellite had the same fix. I added a fan which helps. Another solution is to go to a second hand store, find 3 power suplies (15v,15v, 5V) and put them in place of the existing one. I am considering that myself as the firewire packed it in again last month and I had to jump over to the other 5v regulator to get it going again, even tho it was only 0.2 v short! Cheers, Sandrine
Jun 20, 2011 | Phonic Helix18fw 18 Channel Mixer with...
The large blue panel illuminates but has no legened or text. All other controls which are normally illuminated are off
Check the poower supply. It sounds like the microprocessor in the unit is not being reset and is not functioning.
There probably is a 5 volt supply that has partially failed.
Nov 22, 2009 | Stanton C314 Tabletop CD and Mp3 Player
My stanton c324 after i put a dics in it reads "no disc" what happend to it and how can i get it fixed?
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Oct 28, 2009 | Stanton C314 Tabletop CD and Mp3 Player
My Fender Passport stays in protect mode.
I have one that has done the same. It is the next smaller size. The power supply fried a toroidal inductor in mine. Frankly, these things are a major pain to work on. You have to usually remove the front panel before you can remove the back power supply and power amp section.
If you have warranty coverage USE IT !!!
The protect feature in mine monitors the power supply load and shuts down the supply if it senses overload. They are hard to work on as you have to bypass the protect to troubleshoot and get to the root cause.
Use the old light bulb in series trick to limit the current.
Sep 23, 2009 | Fender Passport Deluxe 500watt Sound...
Power supply cooked
There isn't anything in the power supply you cannot rebuild except the transformer.
BUT you should verify that something in the mixer didn't short out and damage the supply.
After you relace the smoked parts (likely the TOP245Y offline regulator chip is gonzo... then you use this trick to restart the unit safely:
Put a 60 Watt light bulb in series with the hot side of the input power line. I would recommend you use an ISOLATION transformer when working on the power line side of this for safety.
Jan 17, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Stanton C314 Tabletop CD and Mp3 Player Logo
77 people viewed this question
Top Stanton Music Experts
Michial Gueffroy
Oloyede Monsuru
sreenivask
sreenivask
Are you a Stanton Music Expert? Answer questions, earn points and help others
