Question about Panasonic DVD-LS850
Panasonic DVD ls 850 , H03 Code error
Panasonic DVD ls 850 , H03 Code error , please can anyone assist me how to fix this ????
I have an LS82 and the following advice from www.avsforum.com fixed the problem for me. Note that the number of screws that hold the bottom on the machine vary depending on the model. Also the server frame might be plastic instead of metal:
Originally Posted by Hossam fixing code H03is very simple but needs some courrage and small philips screw driver.
the problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft
I do believe when we press the back space for long time it will take the laser lamb beyond its limit and get stuck at the end of the rotating shaft so the servo motor gets difficulty and resistance to get it back to tract
all you have to do is open the back of the LS50 " 12 small screws"
panasonic DVD ls 850  , H03 Code error - mad.gif when you remove the back cover be carful not to damage the cables mad.gif .
you will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions
remove the whole structre and turn it upside down slowly
move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck
and it will work perfect after that
return the back cover and screw the 12 screws and you are done
Posted on Jun 13, 2008
  • 3 Answers
I used the solution posted above and have successfully fixed the player. Thanks to bytecrawler for posting this. My daily mass transit commutes are now much more tolerable than before.
One piece of advice I'd give to anyone attempting to repair the unit, is to do a thorough vacuuming of the interior once the case is opened. Mine was a gift to my son who is gone to college. He used it while eating lots of snacks, thus resulting in a bunch of **** getting sucked into the unit somehow. It only takes small particles of junk to clog the tiny gears which operate the optical drive listed above, and it required implementing a repair 3 times until all the particles were removed.
Besides a vacuum, try using a q-tip to lift any dust or tiny particles remaining on the actual gears or the silver axel attached to the main gear. Be very careful snapping the unit back together.
I purchased a tiny precision phillips screwdriver set with a variety of tiny 0-3 mm phillips heads to do the job at Lowes, $6 cost.
Posted on Sep 24, 2008
I was told by a close friend(Authorized Repair Centre) that,the reason Panasonic
discontinued the LS82 and came out with LS86 is because of the Head Rest Mount. The DVD was spinning in Vertical Mode instead of Horizontal.And the bumps it took,while attached to the seat was too much for the Laser assembly.
LS86 is a replica of LS82 just black in color. It Uses the Battery CGR-H712 same like LS 82. Power consumption on both is 22 watts.Yet they claim its 13 hrs. Thats bunch of BS. I have both ,which I bench tested with same settings. And it lasted between 8.5 to 8.75 hrs.Towards the end it was struggling.
Posted on Aug 01, 2008
Panasonic dvd-lx95 error code h03
Lube up the slider that the laser slides on (slides in towards the center of disc and back out). Check for any debris that may be present.
Download Panasonic DVD LX95 Manual
Oct 11, 2013 | Panasonic DVD-LX95
H03 Error
This problem is the laser optics in the wrong position.
Try to move it carefully by hand to the left near the spindle.
It may be stuck on the right side.
Please let us know what you see!
Jan 05, 2008 | Panasonic DVD-LX97 Portable DVD Player
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Panasonic DVD-LS850 Logo
596 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
