My Sony Model # RDR-HXD760 DVD Recorder turns itself off and then comes back on with "Welcome" in window. I used to get it to work by turning power off, unplugging from power and set it up again but this no longer works.
I have the same problem. Just stopped working yesterday and I cannot turn on the device.
Posted on Jan 10, 2011
  • prh-18 Feb 04, 2011
    More people have the same problem.
    Look at: http://www.mundodvd.com/showthread.php?t...
    By the moment, any solution...
SONY RDR-HX950 is showing WELCOME in display at startup, nothing else happends
i have a sony HXD-1065 which was doing exactly the same thing.
i searched loads of forums to get some idea of the cause but nothing.
to cut a long story short, i put the recorder away in a cupboard for approx 4 months then just as i was about to list it on ebay as faulty i thought i'd just switch it on and see what happens and it came on and loaded up as it should with no problem so i unplugged it and plugged it back in several times to see if the permanent welcome message came back but it just loaded and has worked perfect for the last 5 or 6 months.
i found out later that the memory capacitor needs to fully discharge before it can reset itself on power-up.
i'm not sure exactly how long this takes but it took me 4 months to find it works again.
Jun 30, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My DVD Recorder Won't Start
Sometimes, the Sony documentation recommends unplugging the DVD Recorder for at least 30 minutes, instead of the regular 15 seconds. I know this timing makes a difference on DVR's.
Jun 25, 2009 | Sony RDR-GX300 DVD Recorder
Sony DVD recorder RDH-HXD760
I am experiencing exactly the same problem. I think this product/model is a lemon. The stated issue of a faulty optical lens could be true in that I have had untold failures during playback (skipping chapters) especially of rental dvd even after disk cleaning etc. I guess I will need to have my set fixed (only if I can get warranty) or buy another product (possibly not Sony this time). Sometimes I wonder if these conditions are planned to occur in support of the economy. Phill W.
Jun 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVD recorder won't start up properly
model number :RDH-HXD760. The problem is it won't start up correctly. The welcome message stay on and nothing further happens.
I have replaced all the caps( C105 400V 120uF and 2 of 10V 3900uF no needs) in power supply. It back to work !!!
John Chew
Apr 08, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Dvd frozen
any storms around? sounds like a power spike tanked it
Jul 26, 2017 | Sony RDR-HX727 160Gb DVD Recorder / HDD...
My sony hd dvd recorder RDR-HXD 760 wont turn on or off, it just sits half way and says welcome, have tried holding on/off button down which does work for a bit the it comes back on by itself and goes back...
I had the same problem, my recorder was past it's warranty though. So I opened the case (4 screws on sides & 3 [silver] screws on rear) then unsecured the HDD (4 screws with rubber grommets and 1 screw with thin metal flange) I then disconnected the data and power cable (as illustrated on HDD) powered the whole unit up and got nothing (obviously) reconnected the HDD and plugged the unit in. It powered up and then turned itself off. I then turned it on using the power button and voila, it worked perfectly! All HDD stored videos were still there too! The unit even held the same time.
May 22, 2008 | Televison & Video
Childblock
Easy fix; worked for me.
Jun 14, 2007 | Sony RDR-GX315 DVD Recorder
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
Electro Med Services...
