Question about Panasonic TH-50PX75U Plasma HDTV
10 red blinking lights on my Panasonic Plasma
  • josown94 Oct 22, 2010
    I researched this on the internet for days and finally decided to fix it myself. You were exactly right about the problem! I was able to buy the A-board also known as Digital Video Board - TNPH0716 / ENGE6604KF online for $54.95 and this single mom that is more girlie than a princess fixed that stupid TV! Thanks a million for your help!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. 10 blink error in your Plasma TV means that the A Board has gone bad and should be replaced. You are right, this issue is caused due to overheating and the capacitor(s) goes bad causing these issues. You can also open the back of the unit and check the main board (A Board) first for any blown/bad components/capacitors as the board itself is around $250. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 14, 2010
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
  • 8457 Answers
SOURCE: plasma panasonic headache
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 08, 2010
Testimonial: "ur the don ,will sorce a powerboard .thanx"
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
I bought this tv in August of 2008. First episode occurred in October of 2009 - after manufacturer warranty had expired. It returned back to normal. Second episode occurred in March of 2010 and never got the unit to power up.
I had an electronic service center check it out. Turns out it's a defective power unit that's misfiring. The misfire triggers the overheat error code.
Panasonic retailer wanted $575 for parts and labor.
Service center executed finely and strapped on a 6 month warranty for $375.
I will be faxing a copy of the invoice and original receipt for a reimbursement.
Posted on Apr 02, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
Panasonic plasma red light blink 10 times
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS.
These are the faulty boards and sections to be checked. Just visit the site named 'Electro-help'. Blinking codes and repair work with Panasonic plasma TVs are described in detail. Check this link, and select the site. Pull up older posts there.
Jul 21, 2012 | Televison & Video
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic TH-50PX75U Plasma HDTV Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
