Question about Tally T5023 Plus Matrix Printer
We have purchased Tally DASCOM 1318, we encountered problem during printing, how to change the font size from 10cpi to 12cpi, or how to edit default printer settings on tally 1318
  • 21 Answers
The user guide which you can download here
http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=250&Itemid=48&lang=en
will guide you through the menu settings.
Posted on Dec 04, 2010
Can't find driver for tally t2280 sprintpro
Have a look an the manufacturers web site (Dascom)
http://www.dascom.co.uk/Support/Default.aspx?type_id=3&info_id=3&itemid=15&name=T2280%&act=4
Jan 08, 2013 | TallyGenicom 2280 Matrix Printer
How to change fonts size in tally 7.20
HI,
There is an Utility in your Windows.
If you insist i show you but it may be risky Overriding your Original Fonts..
Press WinKey + R it will start Run.
Enter "EUDCEDIT" w/o ' " ' and press enter an Hidden Windows Font Utility will appear.
Select the Fonts you want and override it to "Times New Roman"
All the Fonts in Tally uses Default System Fonts.
GOODLUCK
Jan 19, 2011 | Computers & Internet
How to change pitch from 10cpi to 12cpi in Epson lx300+II
A complete user manual can be downloaded HERE.
Follow the instructions starting from page 2-19.
Dec 23, 2010 | Epson LX-300+ II Matrix Printer
I'm using tally 7.2, while printing cheque font size is very small how i can increase the font size? kindly help.
to increase the font size in the printing cheque is just simple go on to (or) press F!! key on the cheque printing option will available on there on the give yes . and then some kind of list will available on there on the list read the sentence one by one the font increasing size is available on there give the correct font size as a number for example (60)
Jan 21, 2010 | Tally T6218 Matrix Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
Our 5040 tally printer is not being detected by a computer running on Xp and we have tried both parallel and usb cables.
I would guess that the printer is set to use the Serial Interface. I think this is the default interface setting on the 5040, hence the USB and parallel interface will be disabled.
You can change which interface is active from within the printer menu, once you have enabled the USB interface the PC should then detect the printer when you plug it in.
Details on entering the Menu on the 5040 can be found on the Dascom web site; http://dascom.firma.cc/support2/technical_notes/serial_matrix/5040/5040_tn004.htm
Oct 08, 2009 | TallyGenicom Tally 5040 Passbook Matrix...
PRINTER SPEED
The print speed of the T2155 when printing at 10CPI is 550 Charaters Per Second.
The direct repalcement for the T2155 would be the 2265Plus available from Dascom, for details see;
Jul 23, 2009 | Tally Serial Matrix T2155 Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
PITCH Changing
you must enter in set up mode to printer,press the lf/ff buton and turn on the printer-that is the case in one type of setup firmare ,if you not enter in set up mode to try the same way with other buttons.in the set up printer print you the small guide,then you must foolw his until you reach a change pitch.
Mar 08, 2008 | Epson LX-300 Matrix Printer
Tally T5023 Plus Matrix Printer Logo
265 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
