Question about Compaq Armada E500 Notebook
I CANT GET PAST THE POWER-ON PASSWORD KEY - Compaq Armada E500 Notebook
I cant remember the password for zeepad 7.0, how do I get past the screen lock?
You can write any notebook your password if you can not mind password now you have option you can call device support help line number.
Jan 19, 2015 | ZeepadTM 7" Zeepad 7.0 Andoid 4.0...
The number four on my laptop is not working
To get around the problem, open a text file (e.g. notepad but not word)
type your password and for the number 4, copy it from a website ) and paste it into the text file. (So you could copy it from this page, just highlight the number 4 here and then right click, copy and then go to your notepad file and paste it in).
When you have your password composed in the text file, highlight it and copy then paste it into the password field for your email. Make sure you copy only the password and no spaces that might appear at the end of the password.
To fix the number 4 key, you might be able to gently pry it off, clean the area gently with a cotton tip ... replace the key. Sometimes they are just dirty. But be very careful, you can end up damaging more than just the one key.
It is quite easy to replace keyboards on laptops so if you have a friend who is a fix it sort of person...just google replace keyboard [enter your laptop name] and you'll find a video or instructions.
Aug 05, 2014 | Toshiba Computers & Internet
Do not have login password or reset disc
Turn off the computer and unplug it. Allow the power to discharge.
Open the tower and look on the mother board. you should see a large watch battery. remove it for at least a minute to 5 minutes then replace it. close the tower and power back up. this should remove the password.
Dec 20, 2013 | Computers & Internet
Power On Password
there should be a function key when your computer comes on usually f8 or f12 cant really remember but it goes into your ios setup . try it...
Mar 28, 2012 | HP Computers & Internet
Cant boot up my toshiba lap top. it comes up asking for the BIOS password then shuts down after 3 tries! have tried all the F keys, shift key and removing battery!
the only way to get past the bios password is to open up the case and try to find a jumper on the main board that says bios reset, close that jumper and turn on the computer for one boot, power down and remove the jumper, after that the bios should be reset(bios passwords are usually set as a security measure that is not easy for the average user to bypass such as a windows one that can be removed by formatting the drive and reinstalling windows)
Jan 22, 2011 | Toshiba Portege S100-S1133 Notebook
I can't find my password wep
You MUST have generated, and recorded that, when setting up the Router for the FIRST time, IF you do NOT have it recorded, than you MUST set up the router again, this time, saving the KEY, now as it is 128 number number, it's not feasible, to write it down, so when you are Generating the KEY, you copy/paste it to a notepad document, save that and put it on a USB drive, now you take said USB Drive, to any "Client" PC's and copy/paste in into the required "Field" when asked, at login to network. All is explained in the manual.
kbserver.netgear.com/pdf/dg834_dg834b_ref_manual_03Jun05.pdf Manual link above.
Apr 16, 2010 | NetGear DG834 Router
How do I set up a password to make my Belkin54g a WPA?
You will have to open a browser, and into the address bar, type http:192 168.2.1, use admin as Login & password is blank, After login, you go to security settings and "Generate a WEP KEY" write this down. Better yet copy/paste it to a notepad document & save. Now you use this key on the "Client" computer when you try to access that network. You will be asked for your WEP Key, simply copy/paste it, from you notepad document, into the box, or type it in if you wish.
Dec 29, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
CANT ACCESS MY AIM ACCOUNT IT SAYING INVALID PASSWORD I KNOW IT IS THE RIGHT PASSWORD MY AIM IS IAMKAONASIS
If you are sure that the password is correct, then type your password in a text editor, then copy it and paste in your password box of AIM. There could be some problem with the keys which will be clear to you, once you type in your text editor.
Oct 31, 2009 | AOL Instant Messenger
Help cant get past 1st screen on my apple g3
Ummm... I seriously doubt so with Apple Mac. There is with Windows thou. Yet another reason to change!
Dec 02, 2007 | Apple 350 Mhz Processor for all G3...
Compaq Armada E500 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
