Question about Sony KV-35XBR48 35" TV
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
  • pvxyz Nov 06, 2010
    i found the problem i believe the power supply board ,i found if i lift the back of the board no problem lines gone board must be warped and to diffulcult to replace ill try wedgeing it up and giving it try parts froms sony crt board i found discontinued..
    Top Expert:
  • Sony Master
  • 74,383 Answers
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Posted on Oct 14, 2010
  • 2 more comments
  • pvxyz Oct 14, 2010
    thanks but what is the crt base
  • The Knight
    The Knight Oct 15, 2010
    CRT base can be located on crt board, pluged into the back side of the neck of the picture tube. CRT base means Cathode Ray Tube [Picture tube] base. The plugin socket that gets into connect the picture tube, is soldered to a printed cricuit board which can be located on the picture tube base board. The contacts of connection may be poor along with time. Things that the matter is clear.
  • The Knight
    The Knight Oct 17, 2010
    CRT base means the socket the pluged into the base of Cathode Ray Tume [Picture Tube] which can be located on the picture tube base card atteched to the base of the picture tube. This socket is soldered directly to the bace card. It can be desodered and taken out after pluging out the base card from the base of the picture tube. Usually this one is called picture tube base for ease.
  • The Knight
    The Knight Nov 06, 2010
    As you located the fault point, there may be some loose soldering somewhere it it cauaing power supply regulation section cannot control the output voltage to the main board. Now we are clear that the fault is due to a loose soldering. ok. But you shoud make the board uside down to make any solerings on it. Try it by any way. If you lift and place something under it to make it on that position, sometimes the tv will work temperorly, but it is not a parmanent solution. You should locate the loose point and must solder it. Try it, you can. Wish you sucess.
Retrace horizontal line
It seems to be some line frequency interference is effecting the picture.
Jun 07, 2013 | Televison & Video
Sony KV-35XBR48 has a burn smell, won't turn on. Work fine the day before. Power supply? Thanks
yes. has a power suplly kit. common problem. consists of two transistors two resistors, and thermistors. its called a sony service kit
Nov 17, 2009 | Sony KV-35XBR48 35" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Tv turns off while watching then back on
Dry joints, check solder around the power supply and horizontal output stage....Phil
May 18, 2009 | Sony KV-35XBR48 35" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
168 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
