Panasonic pabx - KX TA308 The system is set to ring on all phone in the evening. So we need to change the time in the system to coinside with daylight saving. How Please? In the past we have paid a tech to do this and we don't want to keep paying. Regards Colin
  • 2,460 Answers
From the Manager or operator's phone (usually ext 101) press PROGRAM and dial 0 +
Year (00-99), Month (01-12), Day (01-31), Day of the week (0-6: Sun-Sat), Hour (01-
12), Minute (00-59), AM/PM (0/1) and STORE.
This changes the time, but you may have CID changing it back. That event usually takes place about the first call after 2 or 3 AM daily.
Carl
Posted on Oct 14, 2010
KX TA308 how to disable 2 locals Ring sametime
There are two possibilities, you have to check to confirm. Either the two were physically wired in parallel or through programming they were configured to ring simultaneously. Start by checking if the two were physically wired in parallel. One way would be to establish how many extensions you have altogether and is it equal or less than the total number of extension ports available on the KX-TA308?
Apr 03, 2014 | Panasonic KX-TA308 Phone
How can I change line voltage from 24V to 48V in KX-TA308 ?
Why? A TA-308 as well as all Panasonic systems run on 24 volts, even the TDA/TDE. The quickest way to do that, and very expensive, was a Proctor Long Line Adapter (46222/46224). The only time we ever had to use one was to bring up the line voltage of a Merlin Legend extension to interface to a Panasonic system we were using as a factory intercom. The intended purpose is for off-premise extensions as they provide high voltage ringing and protect the system it's attached on.
Proctor is long gone, but Viking Electronics makes an exact replacement. Here are the specs http://www.vikingelectronics.com/products/pdf/lla-4.pdf They also run about $500 for 4 ports.
Carl
Aug 29, 2011 | Panasonic KX-TA308 Phone
My problem is that i have pabx kx-ta308,and iwant install it,I need to know every number i will use to each line and if not programed,I need the help how to program it.
Panasonic made 2 TA-308's, one for the US market and one for worldwide. It's similar in operation to the 624 and those manuals are available on the internet. There's not much to them, it has 11 modular jacks and 2 1/8" (350mm) jacks on the side (top) that interfaces to the 3 lines and 8 phones with music and paging ports. At the least, there's an installation manual and a user's manual. Later systems added a separate programming manual.
Carl
Jun 06, 2011 | Panasonic KX-TA308 Phone
Normally all thes phone call the standard ext 101 if they want to make a call but I am trying to set direct lines for some of them so they ll not have to call the standard whenever they need to call . ...
you have to do that in the pabx setting where by you set all out going calls to be calling direct but all incoming calls to be calling to the switchboard first so change the call restriction feature
May 18, 2011 | Panasonic KX-T7730 Corded Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Kx-t77730
in the left side of phone is a ringer setting key, put it in big bell symbol
Aug 14, 2008 | Panasonic KX-T7730 Corded Phone
Incoming call to one extension only at night
Answered elsewhere, but night ring is programmed in system option 409.
Carl
Jun 24, 2008 | Panasonic KX-TA308 Phone
134 people viewed this question
jasbo
jasbo
