Question about Microwave Ovens
VEDO5271SS Viking 27" Professional Ultra-Premium Premiere Double Oven - Stainless Steel care and use manual
  • 8,197 Answers
You can get the manual on the link below.
http://www.ajmadison.com/ajmadison/itemdocs/m720042_f20362.pdf
Cleaning tips on this link below.
http://www.ajmadison.com/ajmadison/itemdocs/m90036_cleaning_tips.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 14, 2010
Testimonial: "Response was in seconds. Wow! Thank you."
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
Tip
Using stainless steel utensils in a microwave oven
Every one knows that one cannot use metal utensils/bowls in a microwave oven.
But did you know that this does not apply to a utensil/bowl made out of stainless steel?
Try it this way.
Put some water in a stainless steel container and place it in the microwave for 5 seconds.The water will heat up without any sparks being created.
One could actually heat up anything in this way without any danger of causing a fire.
on Apr 10, 2014 | Microwave Ovens
My electric lower oven doesn't get any heat.
Could be a lot of things, door lock switches, bad element, a fuse, the thermostat a broken wire or cold solder joint. etc
Good luck
Feb 20, 2014 | GE Profile 30 " Stainless Steel Built-In...
How do you change the clock on a GE GMOG28ECP(A)SS Stainless Steel Microwave Oven?
You can download GE owner's manuals and installation instructions here.
Oct 24, 2012 | GE GMOG28ECPS STAINLESS STEEL MICROWAVE...
Magnatron blew out
The magnetron will need to be replaced with the original, aftermarket are cheaper but will only last several month's, you may have secondary problems that are not evident. I suggest a professional to go over the microwave oven to assess cost.
Apr 17, 2012 | Electrolux EI30BM55HS Stainless Steel...
My viking professional microwave is shooting sparks and caused a burn mark on the inside of the oven wall? Can I fix it or is it shot?
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the metal of the oven wall is burned or chipped, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth, then apply paint.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
May 27, 2010 | Viking VMOC205SS Microwave Oven
Aplliance fronts in stainless steel
I'm not sure about some of those appliances but ApplianceArt.com maybe able to help you. They sell stainless panels as well as the Softmetal adhesive stainless that's been on HGTV's "I Want that," "Design on a Dime," and "Real Estate Intervention." And I think some others.
May 08, 2009 | Maytag MMV4205 Microwave Oven
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
