Question about Honeywell FF12HH Thermostat
Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall.
  • Honeywell Master
  • 43,501 Answers
Hook the black wire to the "R" terminal and the white wire to the "W" terminal...
That's all you have to do... then program the t-stat...
heatman101
Posted on Oct 14, 2010
Testimonial: "Thank you."
Where do I put the wires on my honeywell thermostat RTH7600. they are black green red and white
This is the official installation guide for your thermostat. Go here:
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
Where does the W2 wire go?
w2 wire is second stage heat does your furnace have two stages.look at gas valve it would have 2 valves/ sol w2 will go to w2 on stat. if a single stage furnace w2 is not used
Jan 25, 2010 | Honeywell Programmable Thermostat Heater
Wiring with Honeywell RTH6400
I have the same problem. I am Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall. Do I have the wrong thermostat. The manual doesn't explain this siutation.
Thanks!
Dec 29, 2009 | Honeywell FF12HH Thermostat
I am tying to install an RTH6400 5 in 1 thermostat but the colors of wires i have on my wall are RED, GREEN, BLUE AND BLACK, where as the book has RED , YELLOW,WHITE AND BLUE. please which do i connect to...
You need to open up the panel at your furnace(air handler) and find the terminal strip and see what your existing thermostat wires are connected to. Normally your red wire connects to the R terminal(24 volts), the yellow wire to the Y1 terminal(cooling), the white wire to the W1 terminal(heating), the green wire to the G terminal(indoor fan). You can use whatever color of wire you have existing, just make sure that the R,W1,Y1,and G wires at the furnace match the R,W1,Y1, and G terminal screws at the thermostat. Also make sure the power to the furnace(air handler) is turned off before you make any wiring connections at the thermostat or furnace.This is very important! If you don't and you short any wires to ground(especially the R wire) you will possibly ruin the system step down transformer or blow the low voltage fuse.
Nov 10, 2009 | Honeywell Electronic Programmable...
I bought a honeywell ct3200 and not sure how to hook it up to a two wire system. The wires coming out wall are black and white
If you just have two wires coming from the wall then attach them to the terminals marked R (may say Rc and or Rh, usually has a jumper installed between the two) and W. Hope this helps
Oct 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
My RTH6400 honeywell thermostat the heat comes on with seeting on cool
You have the wires crossed in back of the thermostat. Check the back.It should be color coded like a telephone jack is.
Jul 26, 2009 | Honeywell Heat/Cool Thermostat
Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Honeywell FF12HH Thermostat Logo
360 people viewed this question
Top Honeywell Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Honeywell Hardware and Accessory Expert? Answer questions, earn points and help others
