Question about ASUS WL-500g Wireless Router (WL500GDLX)
Network printing suddenly stopped working
I've had an HP LaserJet 3330 set up as the network printer through my Asus router for over three years. All of a sudden no one on my home network can print through it. The printer is recognized by the router and shows up as on-line in the router control panel, and it shows up as "ready" on all the computers in the network. But anyone who tries to print gets an error.
When I connect the printer directly to my computer it prints fine.
Nothing changed in my home network except one thing: my son's laptop, running Vista, used the network printer for the first time, with no problem. The next day no one can print. It isn't Vista that's the problem: my wife's computer runs Vista and never had an issue with the network printer. The other computers run Win XP. Note that the WinXP SP3 update had no effect on anything.
I have tried resetting the router, resetting the printer, removing the printer and reinstalling it on every computer in the network. Turned off every firewall just to see if that made a difference. Nothing seems to help.
Any ideas???
  • Billingsgate Jun 02, 2008
    Hi. Thanks for responding so quickly! Actually, I don't use dynamic IPs. Each computer has an assigned IP, and the printer is always the same IP as the router itself. There are 2 wired directly to the router, another 4 wired through a switching box into the router and 2 wireless laptops. Yet the problem was identical on all computers, whether directly wired, through the box, or wireless, on both Win XP and Vista. To me it seems something within the router configuration was messing up.
    Was?
    Yes. Mysteriously, everything started working, for no apparent reason, after 24 hours of not working. Again, I didn't change a thing.
    Is it possible my router is dying? It's only around 3 years old. I'm still trying to figure out what to do if it happens again. I'm not a technician by any means, and set up the network through luck, trial and error, not because I know what I'm doing. Yet it worked flawlessly for 3 years.
  • Billingsgate Jun 03, 2008
    Well, I've been using the switch for 6 months without any incident. It's an 8-port switch, quite new. The printer is connected to the USB port on the Asus router.
    What is connected to the switch (wired): 3 computers and 1 Squeezebox (Internet radio device). What is connected to the router (wired): 1 computer, 1 Squeezebox, 1 printer, and the switch box.
    When the problem was occuring, even if the switch was off and the only machines turned on were my computer and the printer (both wired directly to the router), the problem was still there.
    The problem has not (yet) re-occurred, so for now there's not much I can do to trace what happened.
    Thanks again for your thoughtful advice and attention to this matter. If the problem happens again, I hope you'll be able to help me. Otherwise, all I can do for now is hope it doesn't happen again.
    Scholar:
  • 49 Answers
Perhaps you might wanna try checking the IP address of the printer and see if it matches that of the ones that are mapped in each individual computer. There might be many factors in the "strange" events that have occured (PC gremlins, i call it). That should be an initial starting point.
Resetting the router wouldnt help, cause it is the router that issues different dynamic IP addresses (otherwise known as DHPC) to each and eveny node connected to the netwrok as well.
Another important thing to note is HOW these devices are connected to the router. Wirelessly? Wired connection? The fact that you can see the printer via the router means that there is no problem with the router's end, so the problem lies in the intermidiate connection from the computers to the router. Try to work on this angle. Thanks.
-Technomancer
Posted on Jun 02, 2008
  • Rishi Dave Nair
    Rishi Dave Nair Jun 03, 2008
    [quote]There are 2 wired directly to the router, another 4 wired through a switching box into the router and 2 wireless laptops. [unquote]
    Wait, there's a switch involved? This makes it loads easier! How long has this switch been in place. Before you answer that question, lemme confirm if the switch is used to connect the computers and the printers in your home network. Cause if it is, then, that would explain the phenom in your home, affecting all computers. Perhaps it's time you do an upgrade on the firmware of the switch or replace it altogether. Also, please note that a switch, even a small 8 port one, is used to segregate collision domains. What this means is that, on the switch, each port is treated as it;s own domain, thus, a failure in the switch as a whole or the port where the printer is connected will result in whatever you're experiencing.
    The router you're using from Asus, if loaded with the proper firmware (there are loads of them customised firmware on the net), can be sued to even power a small or medium size enterprise, and since the router itself indicates that you are able to see your printer, and with the introduction of the "switch" in the topic, the fault could very well lie with the switch. Hope this helped. Thanks.
    -Technomancer
  • Rishi Dave Nair
    OK, no problem. Although i hope nothing like this happens again, if such an incident were to ever occur again, hit the ASK button on my profile and i will attend to you asap. Take care.
    - Technomancer
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
Network printer stopped printing
Try disabling the firewall on your computers. You may also try to do a system restore prior to installing the windows update and check if you will be able to print.
Oct 16, 2008 | HP LaserJet 3330 All-In-One Printer
Lynksys WRT300N Wireless Router and using two or three printers on the network
Is the HP working on any machine? You can connect it to any one of the machines and share it.
Now you just find it on the network.
You can purchase a USB to parallel adapter for about $25-35 if none of your PC's have parallel ports.
I would imagine that HP still maintains PCL drivers that will be compatible with 2000/XP. Good luck on the Vista :-)
Carl
Sep 25, 2008 | Linksys WRT300N Wireless Router
HP C6100 Wireless printer has stopped working
The HP C6100 series has had some ip setting issues. One day my printer didn't print. I checked the ip settings on the printer and got some 648.154.1.654 address. I had no clue where this ip number came from, because my router's ip is 192.168.0.1. I went into the settings of my printer and set my ip settings manual. Then I went into the router settings and reserved the ip setting I previously setting on the printer to the printers MAC address. I also set static ip address for each computer on my network. This network response issue started about one year after I purchased the printer. I still lose connection every once in a while, but rebooting the router reconnects the printer and everything sitting in the que to print starts to print. To stablize the issue: upgrade router firmware, set static ip address on your network devices, reserve those ip address in your router, , if all else fails reboot router.
Jan 23, 2008 | HP Photosmart C6100 All-In-One Printer
A new router, recognizes the printer (HP Photosmart) and still won?t print from a distant location on the network.
I?m not sure about this one, but I think you should make sure there?s permission to access (share) the printer in the router and/or printer settings. If the printer is connected directly to the router, check if it?s in the right port and you?re not sending a print request to a different port. If that doesn?t help try to set it to another port in the router.
Feb 22, 2006 | ASUS WL-500B Wireless Router
ASUS WL-500g Wireless Router (WL500GDLX) Logo
398 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
