Question about Logitech Z-5300 Computer Speakers
I have everything plugged in but no sound.. the speakers say the volume is almost all the way up..
  • Logitech Master
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 14, 2010
Brand new out of the box Dell 560 set everything up and plugged in the speakers to the USB and the jack in the back and nothing no sound. the speakers are on, but the machine says no device detected. ...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 11, 2011 | Dell Audio Players & Recorders
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
There is no sound coming out of my speakers but everything is plugged in correctly
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 18, 2010 | M-Audio Computers & Internet
Just bought a new emachine computer with speakers, but the speakers do not work. They are plugged in and still no sound, volume set. ?????
Windows has a habit of muting the sound. Please click open the Volume icon from the right bottom corner of the screen. It is shaped like a big speaker. Unmute everything to get sound from the speakers.
Mar 05, 2010 | E-Machines eMachines Desktop PC
I have some multi speakers but the volume not coming out
You don't give me much to go on so here is everything that I can think of:
Remember that there are two volume settings. The volume knob on the speakers and the volume in the computer. Make sure the speaker and computer volume is up and Mute is off.
Make sure the speakers have power. Most of them have a light to show that they are on.
Make sure the speakers are plugged into the the right port on the computer. The audio out port is usually color-coded green.
You can plug a pair of headphones into the computers audio port to see if they work. This will tell you if the problem is with the computer or the speakers. (Don't put the headphones on for this test, the sound might be very loud.)
The last thing would be if a sound driver is not installed on your computer. If you have a sound driver there is usually a small speaker icon next to your clock. No speaker icon and you may need a driver. You can download a sound/audio driver from your computer manufacturer's website.
I hope this helps.
Jan 29, 2010 | Computers & Internet
Low volume with volume cranked up
Are the speakers battery-powered (with dead batteries?) or AC-powered (but not plugged-in) ?
Do the speakers work correctly when connected to some other desktop or laptop or iPod ?
Oct 09, 2009 | HP Compaq JBL Pro (401508-001) Computer...
JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
May 30, 2009 | JBL CREATURE II Computer Speakers
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
No sound from monitor speakers
The monitor must plug into the PC as the external speakers did.
Apr 16, 2008 | Westinghouse L1928NV Monitor
Logitech Z-5300 Computer Speakers Logo
110 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
